Old April 25th, 2013, 11:13   #16
compu_85
Gadget Guy
compu_85's Avatar
Originally Posted by kjclow View Post
Wonder if this would work on the JSW to have the 110v outlet always hot? Be great for camping trips when you need to charge things.
It might. Does your JSW have two fuses where the OP's (and my) car only have one? The relay powers that entire row of fuses.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old April 25th, 2013, 13:35   #17
charley654
Originally Posted by DieselDubs83 View Post
In testing this circuit there are no other components on it. This is a single relay and single fuse (30A) circuit. The only things on this circuit are the tow outlets.
-Les
Awesome, thank you for posting it.
charley654 is offline   Reply With Quote
Old April 25th, 2013, 16:10   #18
50pascals
You can do the same thing by crimping two spade connectors on a short piece of wire 10 or 12 gauge minimum.
Pull relay,
insert jumper in appropriate sockets where relay used to be
Now power full time with no kluge and taking apart relay.
Takes 5 minutes total.
50pascals is offline   Reply With Quote
Old April 27th, 2013, 00:43   #19
n1acguy
Pull relay,
Exactly what I was thinking. Just need to determine which 2 terminals activate the coil and which 2 are the contacts.
I never have understood the practice of switching off the lighter socket on imports.
n1acguy is offline   Reply With Quote
Old April 27th, 2013, 16:07   #20
Jav9882
Jav9882's Avatar
Fuel Economy: 38-42 MPG at 70 MPH
Man I did this mod and I love it. I wish they came from the factory like this.
Jav9882 is offline   Reply With Quote
Old April 27th, 2013, 17:31   #21
carlrx7
I absolutely love the 12v plugs being switched! Having a dash cam that turns it self on and off without having to unplug and replug everytime is heaven.
my chebbie cars I had to install a switched relay, they are 12v constant, it was a royal pita with the radar detectors, usb car chargers, ect.
the only reason i've want'ed a 12v constant is what you guys have pointed out already, to charge the phone while away inside a store.
-Carl
carlrx7 is offline   Reply With Quote
Old April 28th, 2013, 05:58   #22
irishrob
Fuel Economy: 35.5
Back in the day, maybe an occasional 12V car vac with crappy suction or compressor for tire inflation might be found in the trunks of cars. Cigarette lighters on many cars would work with the ignition off and no one would run down their battery. Now we can power laptops, phones, GPS units, hot plates, wire aftermarket radios, portable DVD players, car seat heaters, 12V impact wrenches for lug nuts, coffee pots, little frying pans, curling irons and yes the list goes on.
My point is simply this: Too many people would run their battery down by forgetting to unplug.
irishrob is offline   Reply With Quote
Old April 28th, 2013, 08:48   #23
charley654
What you are saying is true, but those people would learn it quickly not to leave the gadgets connected, after a couple no start due to dead battery. Failure to learn would simply requier to keep a jumber cable and/or a portable jumper box in the trunk.
Can't really blame the manufacturer for one's own stupidity.
Old April 28th, 2013, 10:34   #24
Revpeach
TDI(s): 2012 Jetta
Fuel Economy: 43
My dodge caravan has the best of both worlds. It has two plugs on the dask, one is switched and one is not. I'm going to make the same mod on my Jetta by using an add a circuit in the fuse box to an extra socket in the cubby ahead of the shifter.
Revpeach is offline   Reply With Quote
Old April 28th, 2013, 13:27   #25
compu_85
Gadget Guy
compu_85's Avatar
Originally Posted by Revpeach View Post
... It has two plugs on the dask, one is switched and one is not. I'm going to make the same mod on my Jetta by using an add a circuit in the fuse box to an extra socket in the cubby ahead of the shifter.
This was my solution as well
-J
Present:
Past:
Old April 30th, 2013, 11:21   #26
r11
And now that you have this "always on" lighter socket, consider investing ~$12 into a solar charger : http://www.harborfreight.com/15-watt...ger-68692.html - 20% (google the coupon, Amazon also sells these ). This will always keep your battery topped off - great for when you don't drive your car for a while.
r11 is offline   Reply With Quote
Old May 1st, 2013, 14:19   #27
Moltenburn
Moltenburn's Avatar
Fuel Economy: 43 MPG
Good mod my man. I am going to go with the spade connectors and wire route but way to experiment and figure this out
Current TDI: 2013 Platinum Grey SE TDI 6M
SOLD: 2010 CW Golf 4dr TDI. 6M, Moon, Cold Weather
Avg MPG
Moltenburn is offline   Reply With Quote
Old September 16th, 2013, 20:46   #28
pparks1
Pull relay,
This does seem like the eaiser route. It's the way I would like to go. There are 4 connectors total on the relay, which two need to be connected in order for this mod to work?
pparks1 is offline   Reply With Quote
Old September 16th, 2013, 23:56   #29
vw_norm
Gone, but not forgotten.
if you look at post #1, its the 2 legs that are perpendicular to each other, where the case is being pried off. Looks like they are labeled 3 and 5. Officially, the schematic shows them as 75 and 30a on the relay base with male spade connectors. They're the bigger tabs to carry the current. 30a is the 12V hot from fuse SB24 (50A in under hood fuse box). The other 2 legs (smaller than the power legs) are labeled 85 (power to relay coil) and 31 (ground).
vw_norm is offline   Reply With Quote
Old September 17th, 2013, 06:36   #30
pparks1
Thank you very much for the detailed answer. I'm sure that others will find this helpful as well.
HOW TO/DIY Disassemble 12V Power Outlet (w/o using a hammer) manual_tranny TDI 101 10 November 18th, 2014 10:52
12v Power Outlet Sprocket VW B5 Passat TDIs 8 August 22nd, 2012 05:54
12v power outlet always on fix? natureboy68 VW MKIV-A4 TDIs (VE and PD) 1 July 11th, 2008 19:25
Constant 12V Power in 2006 Jetta winnipegk5 Upgrades (non TDI Engine related) 1 August 13th, 2006 12:50
12V power outlet fuse edpipeline VW MKIV-A4 TDIs (VE and PD) 0 October 26th, 2003 14:10
Page generated in 0.18592 seconds with 11 queries
[Output: 133.41 Kb. compressed to 112.32 Kb. by saving 21.09 Kb. (15.81%)]
