Old April 24th, 2013, 14:33   #1
DieselDubs83
DieselDubs83's Avatar
Default DIY 12v Constant Power Outlet MOD
Did you ever wish that your Passat had a 12V constant outlet? Like for charging your dead phone while in a meeting, or plugging your battery tending solar panel into? This is a simple way to get your factory outlets to be 12V positive even with the key off.
First of all remove this tray by pressing inwards on both sides while maintaining opening pressure. When it releases, simply open it all the way down and pull it off the hinges.
Next you want to shine the light up into the cavity at the back of this drawer and locate the yellow (or greenish) relay (circled in red) with the number 644 on it. pull this relay out by releasing the lock tab (circled in yellow)
Next you need to open the relay up.
Then check out how the contacts inside the relay work and place an object (I used an electrical terminal) in it to hold the contacts together.
Snap the relay back together and enjoy your "always on" 12V outlets. This retains a fully fused circuit and an OEM look. Below is a pic of the fuse for this circuit.
ENJOY!!!!!
http://www.dieseldubs.com
2010 JSW DSG, GTB2260VK + injectors + fuel system ++++++
DieselDubs83 is offline   Reply With Quote
Old April 24th, 2013, 15:18   #2
JARED_LA
Thanks! This is much needed!
JARED_LA is offline   Reply With Quote
Old April 24th, 2013, 16:08   #3
Lightflyer1
Lightflyer1's Avatar
Which outlet(s) does this energize?
2015 Beetle TDI.
Old April 24th, 2013, 16:12   #4
DieselDubs83
The one in the front "hidden compartment" and the one under the armrest.
-Les
Old April 24th, 2013, 16:22   #5
Lightflyer1
Excellent! Thanks for the DIY!
2015 Beetle TDI.
Old April 24th, 2013, 20:23   #6
Jav9882
Jav9882's Avatar
Fuel Economy: 38-42 MPG at 70 MPH
Nice! Finally someone figures this out. Just one question, will this drain the battery's hen the vehicle is off and the outlet is not in use?
Jav9882 is offline   Reply With Quote
Old April 24th, 2013, 20:32   #7
compu_85
Gadget Guy
compu_85's Avatar
No it won't drain the battery down.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old April 24th, 2013, 23:34   #8
vw_norm
Gone, but not forgotten.
Nice mod. I would be concerned that the terminal wedged in there would/might/will loosen and fall out, since the coil will continue to energize each time the car is on and release when turned off, and over time this slight movement can affect the placement of the terminal. Then you got a rattle to deal with. A dab of 5 minute epoxy would hold it in place. Better yet would be to solder a 12 gauge wire jumper across the contacts.
DieselDubs83 - Thanks for the tip on removing the relays. i was trying to remove my aux relays to move some wires around and just couldn't seem to release it. Does the lock tab move out to release or in towards the relay? TIA.
You may affect the battery charge state if you left something plugged in for an extended period without running the car, but that would be an extreme case.
vw_norm is offline   Reply With Quote
Old April 24th, 2013, 23:43   #9
DieselDubs83
That tab is moved away from the relay to release it.
I understand the concern on coming loose. This was on a customers car and he wanted to be able to return to stock should he need to. Make sure that it is wedged tight enough to eliminate any movement when energized. I would probably hot glue mine as it would hold well and yet still remove easily.
-Les
Old April 25th, 2013, 05:58   #10
TDI2000Zim
TDI2000Zim's Avatar
Fuel Economy: 0.0 mpg
That simple?
Cool!!!!!!!!!!
Now, why hasn't VW thought of this...?
My guess is that VW's corporate board is 'too conservative' (think of lawyers and bean counters, instead of engineers).
TDI2000Zim is offline   Reply With Quote
Old April 25th, 2013, 06:04   #11
compu_85
Gadget Guy
compu_85's Avatar
?? no they designed it to be switched from the beginning.
-J
Present:
Past:
Old April 25th, 2013, 07:39   #12
Jav9882
Jav9882's Avatar
I'm definitely doing this today!
Old April 25th, 2013, 10:54   #13
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Wonder if this would work on the JSW to have the 110v outlet always hot? Be great for camping trips when you need to charge things.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old April 25th, 2013, 10:56   #14
charley654
will this relay mod energize other electrical circuits that otherwise would be OFF with the key?
charley654 is offline   Reply With Quote
Old April 25th, 2013, 11:00   #15
DieselDubs83
In testing this circuit there are no other components on it. This is a single relay and single fuse (30A) circuit. The only things on this circuit are the tow outlets.
-Les
HOW TO/DIY Disassemble 12V Power Outlet (w/o using a hammer) manual_tranny TDI 101 10 November 18th, 2014 10:52
12v Power Outlet Sprocket VW B5 Passat TDIs 8 August 22nd, 2012 05:54
12v power outlet always on fix? natureboy68 VW MKIV-A4 TDIs (VE and PD) 1 July 11th, 2008 19:25
Constant 12V Power in 2006 Jetta winnipegk5 Upgrades (non TDI Engine related) 1 August 13th, 2006 12:50
12V power outlet fuse edpipeline VW MKIV-A4 TDIs (VE and PD) 0 October 26th, 2003 14:10
Page generated in 0.16188 seconds with 11 queries
[Output: 132.80 Kb. compressed to 111.04 Kb. by saving 21.76 Kb. (16.39%)]
