Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old June 20th, 2016, 10:45   #76
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Timing belt, water pump and oil/filter change at 298,115 km, then drove 900 km home. Inching to 300k km. . But Looking back at past posts, the last TB changed was done in the fall of 2013 at 242,985 km, so I was way ahead of the interval km-wise; I thought I last replaced the belt earlier after I got the car in my hands and with fewer kms - I guess I should read the posts here first before making big and expensive decisions... The belt still looked great but with the 12mm injection pump I didn't want to push it anywhere near the full 100k km anyway - the first-generation automatic ALHs with 11mm injection pump recommended 40k mile (~65k km) TB replacements so I don't really regret the peace-of-mind of having done it, but it came at an inconvenient time and parts were very hard to get with the perceived rush and urgency that didn't turn out to be the case...
Also fixed a coolant leak at the hoses from the water pump outlet to the cylinder head flange alongside the block.
Edit: I can tell that the stretching TB had retarded the injection timing sufficiently to have a noticeable effect on fuel consumption. Coming down I was doing about 5.4 L/100 km on the highway, returning after I'm at 5.0 (with AC on all the way). The drive is all-freeway over 900 km and I do it so frequently that I'm confidently aware of even small differences in fuel consumption. That alone is worth something. If I average a 5% hit in fuel economy over 100k km interval, based on my Fuelly running cost of 6 cents per km, that will mean $300.
Old June 20th, 2016, 12:18   #77
Alcaid
Alcaid's Avatar
When will we see a sequential compound setup on this one?
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC - 191whp/320wft-lbs @ 4x4 Dynapack
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - Holset HE200WG-5cm + Custom Holset HX30W-12cm compound, 12mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old June 21st, 2016, 15:00   #78
PeeWee
PeeWee's Avatar
Keep on rocking that Audi
Peter
2005 MK 4 Wagon Shadow Blue
HID, GLI lip and side skirts, RXII and Borbet E5, Hidden Hitch, Defender Skid Plate, QLoader, Vagcom 2.0 BKD
PeeWee is offline   Reply With Quote
Old October 8th, 2016, 07:41   #79
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Oil filter change with Mobil 1 0W-40 European Car Formula / Mobil 1 Extended Performance Oil Filter @314136. A little over 100000 km in less than 3 years in my hands. Still soldering on.
Old October 8th, 2016, 08:35   #80
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Looking at your fuelly, you've been all over the place this past year!
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old October 8th, 2016, 18:52   #81
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
British Columbia and back, almost exactly 9000 km - under $450 in fuel and only a flat tire.
ALH 1.9l TDI into a US Audi A4 avant quattro info dino246 TDI Power Enhancements 16 June 6th, 2012 11:37
Audi A4 Avant 1.9TDi Quattro sport.. UK Lofty86 TDI Cars for Sale/Wanted 5 September 11th, 2011 06:57
Audi A4 Avant Quattro 2.5 Tdi Service Manual more ccs VW MKIV-A4 TDIs (VE and PD) 0 June 5th, 2006 05:10
Audi A4 2.5 Tdi Quattro Avant Manuals more ccs VW MKIV-A4 TDIs (VE and PD) 0 June 5th, 2006 05:10
Here's my Audi A4 Avant Quattro 2.5TDi 200BHP 2003 Haralde73 Other TDI/Diesel Picture Gallery 1 August 31st, 2005 14:35
Page generated in 0.14941 seconds with 11 queries
[Output: 80.75 Kb. compressed to 70.89 Kb. by saving 9.86 Kb. (12.21%)]
