Old June 3rd, 2012, 22:41   #31
Niner
duplicate account, banned
Originally Posted by VeeDubTDI View Post
I'll call you tomorrow!
Me too, Group buy. I'd be in for the 6000k version. Have them drop shipped.
Niner is offline   Reply With Quote
Old June 4th, 2012, 04:48   #32
compu_85
Gadget Guy
compu_85's Avatar
Niner I doubt there will be a discount, just order them individually
Old June 4th, 2012, 04:53   #33
r11
Folx,
to clarify, this is the kit to get (subject to one's color temp preferences): http://uspmotorsports.com/product_info.php?products_id=632{98}342
AND
it includes the "bulb adapters" so that use of dremel is no longer required ?
r11 is offline   Reply With Quote
Old June 4th, 2012, 06:03   #34
tdiatlast
Compu 85 and VeeDubTDI are practically neighbors of mine, hence the request to order together.
I didn't intend to start a group buy. Sorry. Next time, I'll phone them...or PM them...
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old June 4th, 2012, 08:03   #35
r11
Also, they talk about disabling DRL after the install - but since in Passats we have *dedicated* DRL bulbs - do we need to disable the DRL ?
I reckon need to disable DRL is only for the cars that put the *regular* beam light bulbs in half-power for DRL, as opposed to cars like ours that use dedicated DRL bulbs instead ?
Old June 4th, 2012, 08:53   #36
Niner
Originally Posted by tdiatlast View Post
compu 85: Thanks for the clarification. Now that I think about it, it makes perfect sense that a photo of a light would have issues.
Hmmm...don't press that "Buy it Now" button until you talk to me...maybe you/we can get a discount if you buy 2 sets? I'm seriously considering it...
So now it's about being neighborly, not the discount?
Old June 4th, 2012, 08:59   #37
Niner
Anyone have any ideas about how the heat of a regeneration might affect the life of the the electronics/ballasts under the hood of a Passat TDI? Just asking if it might be a factor in longevity of the lighting system.
Old June 4th, 2012, 09:44   #38
ValveCoverGasket
i wouldnt worry about it... you can be certain that everything that could have been affected was designed with this in mind
ValveCoverGasket is offline   Reply With Quote
Old June 4th, 2012, 10:39   #39
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Looks like lots of interest in this retrofit... just got off the phone with Niner.
We're gonna go ahead and get the 4300K kit and see what that looks like, although I really liked the color of the 6000K kit. We're also going to get some brighter high beam lamps - probably PIAA or something. I think with the increased output of the low beams, the high beams will look a little wimpy on dark back roads.
I think the install can be done without dremeling any plastic or cutting any wires, but that's Jason's area of expertise, so I'll wait for his write-up.
Regarding group buy, I don't think we'll get any sort of discount... just order at your convenience.
Trusted TDI Mechanics Map || TDIClub Chat
Old June 4th, 2012, 18:06   #40
compu_85
Gadget Guy
compu_85's Avatar
Someone on another forum mentioned a good point... when the HIDs start up they draw a lot of power... probably 15 amps or so. The halogen lamps are under 5. It looks like the Chinese market cars have the HIDs going right to the body control module so I don't think it's a huge issue in this case, but is something to keep in mind.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old June 4th, 2012, 18:16   #41
eprater1
Thought you didn't believe in HIDs, wheels, stereos, ect? Seems like even you are starting to see the benefit of the aftermarket. Hope your install goes well and heat doest effect the ballast, keep us posted.
eprater1 is offline   Reply With Quote
Old June 7th, 2012, 15:29   #42
r11
Got me a 4300K set (see the link I shared above). Install is very easy. I used piercing clips that come with the kit, as opposed to soldering. Kit comes with bulb retainers/adapters - so you don't have to mess with stock ones at all.
About the only thing worth mentioning is how to immobilize the bulbs within the adapters as you insert the whole thing in and twist it to lock. I ended up jamming the ends of the bulbs inside of the adapters with pieces of Styrofoam that I later removed.
If u are result oriented should not take more than 30 mins to install . You mix a six pack in there and then there's no telling
Old June 7th, 2012, 17:55   #43
Good Ol' Boy
VeeDubTDI's Avatar
What do you think about the 4300K color temperature?
Old June 8th, 2012, 06:44   #44
r11
Me likes ... didn't want to look like one of dem boy racers with 6000K
Old June 8th, 2012, 07:17   #45
Good Ol' Boy
VeeDubTDI's Avatar
Pic?
DIY: HID projector complete Retrofit Kits JettaSportTDi Vendor & GroupBuy items for sale 147 October 16th, 2014 00:27
2012 Golf HID's in Canada ??? 8luglogic VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 April 2nd, 2012 14:59
any DIY oil change for 2012 style TDI?? dvandentop VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 March 24th, 2012 18:08
Any DIY for HID Retro Install on 11' Jetta? mact3333 Upgrades (non TDI Engine related) 6 August 31st, 2011 15:55
Jetta Mk4 OEM HID Manual Leveling comprehensive DIY Nitrowolf Upgrades (non TDI Engine related) 8 December 15th, 2005 18:38
Page generated in 0.20209 seconds with 11 queries
[Output: 131.30 Kb. compressed to 110.04 Kb. by saving 21.25 Kb. (16.19%)]
