Old May 28th, 2012, 18:18   #1
Coffeemade
Default 2012 Passat HID DIY Install
I contacted DistantXtremes because I heard from some of my friends they had some very high quality HID kits. I talked it over with their customer service and determined that the best kit was the XE+ Premium 35w Slim H7 Kit in a 6000K color option.
I placed my order and in 3 days they where at my door By accident I got a 35W kit and a 50W kit. They corrected this by overnighting one of each so I could choose. The difference was minor but the 35W had a much cleaner look from the front end....driving down the road they looked very similar and the 35W kits are recommended over 50W kits, less energy usage.
I went to install them without paying any attention to a real DIY but I did read the section of this DIY about the wires and color codes http://www.myturbodiesel.com/forum/48555-post18.html (Thanks TDI Brad)
Please read this whole thing prior to starting so you won't feel like this later.:banghead::banghead::banghead:
The below picture is for reference of what the back of 2012 VW Passat Headlight housing looks like:
This install was done by my friend Jasen and I documented it all. So just ignore the part where I keep saying I, because that was all him. I started by removing the headlight bulb from the driver and to my shock found this:
Yes, VW again has come up with their own unique bulb harness. I was determined to install the HIDs. I did find a set of headlight bulb adaptors from USP (Click here for the link) during my install which was too late and I didn't want to spend $24 for adaptors. I am cheap and with my buddies help and a Dremel we made it work. So in order for the bulb to fit you need to dremel out a nice big hole while retaining the front portion of the housing as seen below.
Once you have done this and saved yourself $24 now for the fun stuff. Install the new HID headlight.
HID bulb
When reinstalling the headlight keep in mind this notch is straight up and down.
Do that for each side.
Now onto wiring, refer to the picture above to locate the headlamp housing harness. Disconnect the harness. (I am terrible at getting these connectors off, so Jasen did that.) On either light you will notice the connector is numbered. The headlight wires are Pin 5 negative(-) and Pin 6 power (+). On both sides the negative wire is brown, but the power wires are different on each side so the driver side driver side is a yellow wire with a black strip and pass side wire is a yellow wire with a blue strip).
So you can splice, tap, or solder the wires. We soldered the wires to the ballasts.
Coffeemade is offline   Reply With Quote
Old May 28th, 2012, 18:18   #2
Coffeemade
I connected the HID harness to the ballasts and turned them on. We accidentally plugged the connector upside down so it was reverse but that doesn't cause damage, unconnected and reconnected and turned the HID on and first words out of my mouth. "Dam, I should have done this months ago!!!"
I was driving down the road back to my house and it was the first time I felt like I was back in my GTI. The lights look awesome and cutoff on the HID is really nice.
This is my google plus photo gallery for the install
All of the above pictures were taken with a camera phone, below are taken with a good camera :-)
Keep in mind the below picture is with HID's and fog lights on.
Click here to check out my google plus album for more photos
Old May 28th, 2012, 18:29   #3
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
More pictures please. Beam pattern, oncoming shots, pattern on a wall, the whole nine yards. Looking forward to seeing these.
Trusted TDI Mechanics Map || TDIClub Chat
Old May 29th, 2012, 22:14   #4
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Oh... I see this not going well...
Fixmy59bug is offline   Reply With Quote
Old May 30th, 2012, 17:31   #5
Coffeemade
Hope you are happy
You could drive 15-20 mins and see them in person.....
Old May 30th, 2012, 17:40   #6
Good Ol' Boy
VeeDubTDI's Avatar
Thank you! Yes - I need to get down there and see what's up. How'z about tomorrow?
Old May 30th, 2012, 20:14   #7
dogger37
dogger37's Avatar
TDI(s): 2012 passat
So you got them to function correctly without any issues? Would the setup you used be able to make the chinese ones work?
dogger37 is offline   Reply With Quote
Old June 1st, 2012, 13:52   #8
Coffeemade
Oh now I see why you tried to meet up last night....sorry I had a really busy day at work and some how missed this. I'm home now
Yeah not one single issue, almost plug and play. Next time I won't wait so long and I am happy I went with the company I did because I know not all HID kits are the same.
Old June 1st, 2012, 18:10   #9
nkgagne
Fuel Economy: See Fuelly in signature
NO!
NO NO NO NO NO!
Either retrofit some proper HID projectors (see theretrofitsource.com) in your housing with a proper beam pattern or live with the halogens! HID "drop-in" kits in halogen reflector housings are as bad as driving around with your high-beams on all the time! It's annoying, rude, unsafe, doesn't give you good light output since it's out of focus, and it bounces back at you in fog and blinds you! Just say HAIL NO!
Bone stock. Dieselgate Stage 1 reflash complete.
nkgagne is offline   Reply With Quote
Old June 1st, 2012, 18:16   #10
Good Ol' Boy
VeeDubTDI's Avatar
Being in the lighting industry, I tend to agree... but I'm not gonna rain on someone's parade. Plenty of that going on lately as it is.
Old June 1st, 2012, 18:24   #11
Coffeemade
I am starting to understand why others with either complete chinese lights or other DIYs aren't taking the time to document and post up DIYs......
I might take a step back myself.
Old June 1st, 2012, 18:28   #12
Good Ol' Boy
VeeDubTDI's Avatar
Not asking you to step back as I'm genuinely interested in your retrofit. From my experience and what I've seen in other cars on the road, many drop in HID retrofit kits have very poor light control. I have seen some cars that respond well to drop in HIDs and I'm very curious to see if the Passat is one of these cars. It also depends on the kit - some are worse than others.
So please, continue sharing!
PS- complete Chinese lights would fulfill the "requirements" set forth by nkgagne since they're factory projector HIDs.
Old June 1st, 2012, 18:31   #13
Coffeemade
[QUOTE=VeeDubTDI;3823377]
/QUOTE]
Maybe just to a more limited audience (you included)
Oh and I would go out and take some more night photos except for this stupid rain. maybe over the weekend,
Old June 1st, 2012, 18:41   #14
Good Ol' Boy
VeeDubTDI's Avatar
Pouring here again... crazy weather today! Tornado and flash flood warnings earlier, now just flash flood warnings.
Stay safe!
Old June 2nd, 2012, 21:46   #15
dogger37
dogger37's Avatar
TDI(s): 2012 passat
Hate to ask the question again but can this kit help make the OEM chinese lights and/or the aftermarket LED/HID lights work?
DIY: HID projector complete Retrofit Kits JettaSportTDi Vendor & GroupBuy items for sale 147 October 16th, 2014 00:27
2012 Golf HID's in Canada ??? 8luglogic VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 April 2nd, 2012 14:59
any DIY oil change for 2012 style TDI?? dvandentop VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 March 24th, 2012 18:08
Any DIY for HID Retro Install on 11' Jetta? mact3333 Upgrades (non TDI Engine related) 6 August 31st, 2011 15:55
Jetta Mk4 OEM HID Manual Leveling comprehensive DIY Nitrowolf Upgrades (non TDI Engine related) 8 December 15th, 2005 18:38
Page generated in 0.16518 seconds with 11 queries
[Output: 137.35 Kb. compressed to 116.11 Kb. by saving 21.24 Kb. (15.47%)]
