Old February 18th, 2012, 16:23   #1
deltatech
Default Bubble gum and bailing wire fix.........
Ok today I found that the mount for my turbo charger servo is corroded and broken at 135k miles. It seams that the vains are moving freely. I can move the servo connecting rod and vains about 5/16". It looks like the turbo and servo are an integral unit and can't be replaced separately so how about a Mcgiver fix? The mount is broken so why couldn't I use some stainless steel safety wire and secure the servo without spending the money on a rebuild turbo???
deltatech is offline   Reply With Quote
Old February 18th, 2012, 17:01   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
You are correct to a point about one unit. You can't purchase them seperatly. Best bet is to find a used actuator here and then make sure you run a belly pan to keep the crap out.
Good luck with the search.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old February 18th, 2012, 17:19   #3
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Try the private forsale/wtb section.
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old February 19th, 2012, 15:29   #4
deltatech
Thanks for the input guys. I keep the stock engine cover on the bottom.
Old February 20th, 2012, 16:20   #5
deltatech
My safety wire idea didn't work. I secured the servo with wire so that it barely moves. Nothing touching the control rod. My car still goes into limp mode. Oh well.
Old February 20th, 2012, 16:33   #6
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
You can try a modified garret actuator and see if it works.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old February 20th, 2012, 16:51   #7
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Bubble gum and bailing wire?
I would think a cross between Rube Goldberg and MacGyver may hold some promise... for instance... a set of pulleys running from the accelerator pedal designed to provide a small time delay between a request for power and the opening of the turbo vane mechanism... of course, that delay should be eliminated for any negative (deceleration) request...
(I need more sleep...)
Yuri
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
Old February 20th, 2012, 17:15   #8
deltatech
ymz---pretty good thanks.
turbocharged798---someone else suggested the Garret actuator from boraautoparts.com-looks like I will have to improvise the mount and connector rod, is that all there is to it?
Best Relay or wire to put hot wire in for External fuel pump torahtom VW MKIII-A3/B4 TDIs 2 November 14th, 2008 00:40
Repairing / replacing a wire harness connector to fix a/c problem. Big Red VW MKIV-A4 TDIs (VE and PD) 1 July 20th, 2006 07:39
chewing gum in floormat! ufoguy TDI 101 14 April 5th, 2004 00:03
GUM BALL RALLY Tazzman Events, Gatherings, Clubs 27 September 16th, 2002 08:26
Pine sap/bubble gum removal Chmeeee TDI 101 3 August 26th, 2002 04:40
Page generated in 0.13733 seconds with 11 queries
[Output: 84.85 Kb. compressed to 72.98 Kb. by saving 11.87 Kb. (13.99%)]
