Old March 7th, 2011, 14:09   #1
delslo
Default brm turbo actuator issue
I have an 06 tdi with an overboosting issue. I had it diagnosed and it turns out that my boost actuator is leaking vaccuum. Is there any way to fix this problem other than replacing the turbo? I need help big time. I need to sell the car so that I can pay my tuiton ASAP.
delslo is offline   Reply With Quote
Old March 7th, 2011, 19:03   #2
2footbraker
2footbraker's Avatar
Maybe try to find a core vnt 15 and pull the actuator off that. Of course it will not have the "smart" sensor on top of the can. Or you could try to open the can and replace the diaphragm, which I assume is what is leaking. Unfortunately they don't sell that actuator separately.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old March 8th, 2011, 06:58   #3
A5INKY
Fuel Economy: pretty good
The smart actuator has a role. It can be tuned around, but I was told my a reputable tuner that you are better off with it than without.
I don't know about availability new but I was able to buy one off a used OEM turbo from one of the trusted mechanics that frequents this site for a good price. You might consider posting a WTB ad in the private seller area and see what turns up. Mechanics do replace failed turbos from time to time and sometimes the actuators are still good.
AFAIK, if an actuator holds vacuum it is usually good, if not it is always bad.
A5INKY is offline   Reply With Quote
BRM Turbo Actuator Replacement flyvsdrive VW MKV-A5 Golf/Jettas 9 June 2nd, 2013 05:47
BRM turbo actuator delslo Private TDI Items for Sale/Wanted 3 March 10th, 2011 18:26
WTB-Actuator for BRM turbo. kjmiv Private TDI Items for Sale/Wanted 8 October 29th, 2010 11:38
WTB: Actuator for BRM turbo....? TdiRacing Private TDI Items for Sale/Wanted 5 August 12th, 2009 20:03
BRM turbo actuator alphaseinor VW MKV-A5 Golf/Jettas 8 August 3rd, 2008 18:22
Page generated in 0.09762 seconds with 11 queries
[Output: 57.42 Kb. compressed to 52.08 Kb. by saving 5.34 Kb. (9.30%)]
