Old January 19th, 2011, 01:00   #1
AKAvant
Default Coolant Flush
I've been dismantling an AHU from a '98 Jetta to use in my tdi swap and when I emptied the coolant system things didn't look very good. It looks like the previous owner had either mixed G12 and green coolant or there is alot of rust in the system. The coolant was greenish with a heavier red sediment that settled to the bottom. Also there was a good deal of plastic/rubber fragments in the fluid.
Any ideas what all this could be from?
So I want to flush whatever remains out of the engine. Is there a way of doing this without running the engine? The motor is still in the car but the radiator has been removed.
Is there a recommended coolant flush additive?
Thanks again!
AKAvant is offline   Reply With Quote
Old January 19th, 2011, 12:29   #2
AKAvant
The car had been sitting for several months outside prior to me buying it. Could this be a factor?
Old January 19th, 2011, 12:40   #3
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
That's not a good sign. While you're in the process of doing your swap, install a new water pump and heater core. You don't want to have to do the heater core a couple of months after you finish the engine swap, and the part itself is very inexpensive.
I'll go out to the garage in a minute to see what kind of coolant flush we have out there. It seems to work pretty well. Make sure that you use plenty of water to flush after doing the chemical flush.
Trusted TDI Mechanics Map || TDIClub Chat
Old January 19th, 2011, 12:48   #4
Abacus
That helpful B4 guy
Abacus's Avatar
Why do the heater core, do you know what kind of work is involved in replacing that?
Flush the heater core, but don't remove it unless it's leaking.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old January 19th, 2011, 13:01   #5
Good Ol' Boy
VeeDubTDI's Avatar
Because it's easier to do it while in the middle of the swap than to do it after the swap is complete.
Yes, I do know what kind of work is involved in it - first hand, which is exactly why I'm telling him to do it now rather than later.
Old January 19th, 2011, 14:13   #6
AKAvant
The engine is getting pulled from it's present location and reinstalled into a B3 Passat. I'm not worried about the present heater core, I just want to clean out the engine itself and remediate any damage. I'm going to do a full timing belt/water pump job before reinstalling it.
I'm thinking I'll hook up the engine to a hose and flush it with hot water, then reinstall the radiator and wiring harness to run it with a coolant flush before draining and flushing it one last time.
Old January 19th, 2011, 15:05   #7
Good Ol' Boy
VeeDubTDI's Avatar
Oh nevermind... I thought you were talking about the car that the engine was going into for some reason.
Old January 19th, 2011, 15:16   #8
Conan
Conan's Avatar
TDI(s): 2003 GLS TDI
Fuel Economy: 32-48
So, it really is true that mixing pink and green makes cottage cheese? I had wondered if that was just another way VW blackmailed us into buying normally cheap consumables like anti-freeze at the dealer. I'd be interested in seeing pictures of the precipitate, just out of morbid curiosity.
Conan is offline   Reply With Quote
Old January 19th, 2011, 15:29   #9
AKAvant
I'll take some pictures of it, it sure isn't pretty.
Anyone know what the particulates in the coolant could be from or caused by? They aren't metallic but black rubber/plastic. I should probably change all the coolant hoses/fittings?
I'm just hoping the headgasket is ok. Compression came in between 360-390psi, on a slightly warm engine.
Old January 19th, 2011, 16:14   #10
Conan
Conan's Avatar
Fuel Economy: 32-48
Did that year have the plastic water pump impeller? That'd be my guess.
Old January 19th, 2011, 16:17   #11
Good Ol' Boy
VeeDubTDI's Avatar
Looks like what we have out in the garage is the Prestone Coolant Flush. I thought it was something different... not sure how well it works.
Old January 19th, 2011, 16:18   #12
Good Ol' Boy
VeeDubTDI's Avatar
Could be the plastic impeller or the hoses and flanges deteriorating. Pink + Green makes for some really nasty stuff. Pull the hoses off and have a look inside. Run your finger around the inside and see what comes out. If it's really gross, I'd go ahead and replace the coolant hoses with new ones.
Old January 19th, 2011, 18:21   #13
Conan
Conan's Avatar
Fuel Economy: 32-48
Isn't all antifreeze basically ethylene glycol and water? What did VW put in the pink stuff that makes it so reactive with other antifreeze? I looked all over (well, I tried NAPA, Car Quest and Checker), and couldn't find any antifreeze that said G12 on it. I found some Pentofrost SF, or something like that. In a white 1.5 litre jug. It said VW on it, but it didn't say G12, so I passed.
Old January 19th, 2011, 18:53   #14
Good Ol' Boy
VeeDubTDI's Avatar
You can't buy G12 at any local auto parts place. Same goes for Ford Motorcraft coolant. Auto parts stores will claim that a lot of their products will work universally, but you have to be careful, especially with the diesels (specifically with cavitation on the PowerStroke).
Old January 19th, 2011, 22:36   #15
cadman1940
Smile Cadman1940
Hey guys the junk in bottom of cooling system is from sulfuric acid build up in block. I have and do still use a cooling system conditioner made by BG products that moves the system from acidic to alkaline on my caddy in just a 12 oz app 1 to 2 times a year. I have a garden PH meter I found at Harbour freight for about $5 and checked against litmus strips that I have and sure makes it easier to and quicker to check coolant. If you mantain ph balance you will never have a radiator or heater core go bad from corrosion. Start this on a brand new vehicle and you can run it till the wheels fall off and cooling system will still be clean and nice. Go to a big truck shop and talk to the better mechanics there and you will find that they will tell you the same thing about not needing to boil out the block on a rebuild. Thanks Eric 03 jetta 40M & 00 cabrio 44M
cadman1940 is offline   Reply With Quote
Coolant Flush? rshelton TDI 101 9 March 18th, 2007 20:35
Coolant flush scknight TDI 101 12 January 31st, 2006 21:03
Coolant Flush Blackknight VW MKIV-A4 TDIs (VE and PD) 5 December 5th, 2004 11:24
coolant flush AlanTDI TDI 101 2 July 18th, 2004 16:14
coolant flush?? Roy Basch VW MKIV-A4 TDIs (VE and PD) 10 April 6th, 2001 21:27
Page generated in 0.17582 seconds with 11 queries
[Output: 130.22 Kb. compressed to 109.02 Kb. by saving 21.20 Kb. (16.28%)]
