Old August 6th, 2009, 22:01   #1
dlh
dlh's Avatar
Default Timing Belt Replacement question?
Hi All,
I purchased my 2001 NB TDI the first part of this year, it had about 90,000 miles logged then and I am around 103,000 now. I have no issues with the car so far and totally love it, especially the 47mpg )).
It was confirmed at the time of purchase that the Timing Belt was replaced at the 60.000 mile interval and was done in 2006. The only info I could not find was if it was a standard 60,000 mile or upgraded to the 100,000 mile timing belt kit.
My question is - Is there any way to tell (visually or any other ) if it has the upgraded 100,000 mile TB kit or the 60,000?
Thanks for your attention!!!
dlh
P.S. I may be a little off on the intervals, but I think you guys know what I mean
dlh is offline   Reply With Quote
Old August 7th, 2009, 05:13   #2
Growler
Got Soot Vendor
Growler's Avatar
take the cover off of the timing belt. if it is smooth, it is the 60k mile belt, if it looks slightly knurled, its the 100k belt.
HOWEVER.
even tho the belt may have been replaced, do you know for sure that the waterpump and rollers and tensioner were replaced ? what about the bolts for the motor mount?
it might be worth your comfort sleeping at night to get it all done properly with a kit from one of our vendors, (boraparts is close to you in UTAH)
basically unless you know for sure that the pieces were replaced, I would start looking to get it redone no later than 120k
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old August 7th, 2009, 09:20   #3
Franko6
The nightmare scenario...
"The timing belt was just done."
The belt jumps time in 500-5000 miles.. bent valve, broken lifters and a big repair bill..
Some people think a 'timing belt job' is the tensioner and the belt.
If the whole job is really done, you can remove the serpentine belt, harmonic balancer and lower timing belt shield to see whether the big roller has been replaced and if the water pump is old/ leaking.
Like Growler says... cheap insurance and peace of mind for an hour's work.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old August 7th, 2009, 09:39   #4
owr084
And if you need someone to do your timing belt right, contact "drivbiwire" He's in Idaho and one of the best TB gurus.
RBB
2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2015 Toyota Sienna XLE, 2017 VW Jetta SEL 1.8T
owr084 is offline   Reply With Quote
Old August 7th, 2009, 09:53   #5
Grady
Grady's Avatar
TDI(s): '01 Jetta
http://drivbiwire.com/default.aspx
Grady is offline   Reply With Quote
Old August 7th, 2009, 09:57   #6
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
I had the same question some time ago w/another TDI. The belts come from a couple mfg's (Gates, etc.) but the new upgraded belt will have a pattern to the back side of it like this:
The original 60k belts are smooth w/no texture. Like mentioned before, the tensioner was upgraded as well for the 100k kits so hopefully they didn't re-use the old one. If it were me, I'd plan on getting it done using a complete kit from one of our own vendors here (dieselgeek, boraparts, tdiparts, etc.) for my own peace of mind.
x2 on using Pete (drivbiwire). He's in Boise and a belt changing machine...
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old August 7th, 2009, 15:39   #7
Havokk
Havokk's Avatar
TDI(s): 1998 Jetta
Fuel Economy: 46-54, better if i were to clean the garbage out of my passanger seat, must be 60lbs of garbage there. who the hell has time for that crap?
im still disappointed they don't make long life belts for the earlier model TDIs :-(
Havokk is offline   Reply With Quote
Old August 8th, 2009, 22:27   #8
dlh
dlh's Avatar
Hi Guys,
Sorry for not getting back sooner, but I appreciate all the reply's!
I was planning on having it re-done at the 120 mile interval anyway, but I figured it would not hurt too see if it was easy to tell if the previous owner had the upgrade kit installed.
Again thanks for all the input and referrals, you all great !!!
dlh
Page generated in 0.15859 seconds with 10 queries
[Output: 83.97 Kb. compressed to 72.04 Kb. by saving 11.94 Kb. (14.22%)]
