Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old April 28th, 2012, 17:17   #16
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Plastic trim (black) on bottom edge of hatch, two screws hold that in inside the pill down handles, once that is removed three 10 mm blots hold the motor to the hatch, unplug the motor .... Done!!
Sent from my iPhone 4S using Tapatalk
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old April 28th, 2012, 19:43   #17
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
Fuel Economy: 850-1000 Km vented
I am willing to bet that none of the people in here have an actual blown or bad motor. It is the linkage that rusts and seizes up. I just fixed this 1 month ago.
To remove the wiper arm, use a gear puller as suggested already, or a special wiper arm removal tool. Princess auto has one for 12$ or so.
Remove the plastic trim on the inside of the hatch. There are 3 bolts or nuts IIRC that hold the motor and linkage mechanism onto the hatch. You have to take the plastic lid off the back of the motor/linkage housing to be able to access the linkage. When that is off, you might have to you a rubber mallet or a piece of wood and a hammer to take the linkage and shaft out of the housing. A bench vise is recommended but not needed. Some 120 grit sand paper and some grease. I use bearing grease for everything, but you can use whatever you have or prefer.
On mine, the shaft was not badly seized in the housing. It was the hinged/articulated linkage that was rusted. Take pictures/notes of how it is assembled, than pry it opened completely. Every piece comes off. Even though it looks like it's not. Sand every one of them until they are clean of rust, lube them up and put them together as they were and you will be surprised at how easy they move now. Fill the housing with grease, put the lid back on the housing, go to the car, plug the wire back in the motor and try your rear wiper. If it spins freely, you're almost done. Put the motor back in the hatch, put the trim back on, install the wiper arm and you're done.
Sorry I have no pictures of this. It's super easy to do and I think vortex or even here might be tutorials for this.
I would be curious how much a new motor/linkage is. And buying one from scrap is not worth it since all MKIV golfs are plagued by this issue. And even if you have your hatch replaced under warranty, they will not replace the wiper motor for free.
2010 Grey Audi A4 Avant 2.0 TFSI Quattro
2004 Tornado Red Audi A4 Avant 1.8T Quattro
Sold: 2003 Reflex Silver Golf TDI
RIP: 1999 Green Passat TDI GLX
RIP: 1999.5 Red Golf TDI
Doc_Oc is offline   Reply With Quote
Old April 29th, 2012, 08:28   #18
yvon g
thanks for your input Doc Oc. it was the linkage assembly in the motor that was seized, however i mushroomed the washer nozzle in the end taking the shaft out of the housing.it was seized in there real good. I'm letting the link ass. soak in diesel fuel to help free up completely before reassembling. do you know if the shaft ass. can be bought separately in order to have washers again or would i have to buy a motor ass.? i can live without the washers....at least i should have a working wiper again. thanks
yvon g
yvon g is offline   Reply With Quote
Old April 29th, 2012, 09:14   #19
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
I'm not sure, but I don't think VW will sell just the linkage. You can ask on the forums and see if anybody has a busted one they are willing to give you or sell for cheap.
Is there no way to fix it? With a small file to go inside and clean the shaft?
I find myself using the rear washer way more than the front one. We have a lot of dirt roads around were I live.
Old April 29th, 2012, 12:11   #20
yvon g
no...the nozzle part is gone. had to hit the end of the shaft quite hard to remove link ass. from housing ...it's broken. i find that the rear window is a magnet for road spray. I'm satisfied if i only have the wiper working but the washer would absolutely would be a bonus.
Old April 29th, 2012, 13:09   #21
yvon g
all back together wiper works like a charm.....thanks again doc co
Old April 30th, 2012, 06:59   #22
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
Any time!
Old May 4th, 2012, 11:03   #23
clamb
clamb's Avatar
I deleted mine as shown in the vortex link. Don't miss it.
2010 Golf wagon; 206K; Malone stage 2; buzzken exhaust. (hers)
2011 Golf Wagon; 185K; stage 2.5 JR tune; buzzken downpipe; JR DSG tune (FOR SALE - $8500)
clamb is offline   Reply With Quote
Old May 4th, 2012, 11:12   #24
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
I would miss mine dearly if I deleted it! Especially in the winter.
Old October 13th, 2012, 05:59   #25
yvon g
rear wiper acting up again. is there a relay that powers the motor?. it starts then stop where ever. some times it won't come on at all. pulled the loom apart at motor, doesn't seem like i have a broken wire.suspect bad relay.
thanks
Old October 13th, 2012, 13:34   #26
JASONP
JASONP's Avatar
Remove the motor and take it apart, there are some electronics in there that switch the direction of rotation , if the sprayer has been leaking at the stem guaranteed there is corrosion and not functioning properly
Old November 25th, 2012, 20:47   #27
DieselDrink
DieselDrink's Avatar
Glad I found this thread. I just took my rear wiper linkage apart. I got all the gears apart inside, but couldn't get the entire shaft out of the housing. I cracked a bit of the black plastic on the outside of the shaft housing banging on it a bit in the process. I did spray anti-seize all over in there, and reassembled the gears etc. It works now.
But the spray nozzle still rotates with the rest of it.
I may just go buy a new one, or a used one and replace the entire thing.
At least I know how to do it now.
2001 Golf TDI
Toronto, Ontario
Montreal I's, Audi TT Shift Linkage, Autometer Phantom Boostgauge, Boostvalve, Ventectomy, CTDI CCV, OMI, PD150 Intake & EGR, Evo Skidplate, TT LCA bushings, KYB AGX, 20thAE springs, South Bend Stage 1 clutch w DMF, PP520, RocketChip Euro 3/2 switchable
DieselDrink is offline   Reply With Quote
Old November 26th, 2012, 08:21   #28
LNXGUY
LNXGUY's Avatar
The wiper on my sisters Golf no longer works, because I'm the family mechanic, of course I get to fix it, lol!
I'm guessing the linkage is seized as well.
Bill
LNXGUY is offline   Reply With Quote
Old April 6th, 2013, 07:30   #29
yvon g
Originally Posted by MOGolf View Post
Yes, the black wire is constant system voltage (fuse 27) when the key switch is in the on position.
The brown wire is ground.
The green/white wire gets power (fuse 24) when the switch is put in the wash position.
The green/red wire gets grounded when the switch is put in the rear wipe or wash positions.
i replaced rear wiper motor last october....worked ok all winter. now every time i turn ignition on, wiper runs constantly for about 6 sweeps then stops at middle of window. checked at connector, my test light is on steady when plugged in to black(constant power) and green/red(signal for wipe). question....is there a module in rear motor to activate the sweep function, or is the intermittent ground signal supposed to come from somewhere else?
Old March 10th, 2017, 18:32   #30
RiceChopper
TDI(s): 2000 Golf GL
Fuel Economy: 40 mpg
yvon, I know it has been nearly four years, but for anyone who may run into this issue, I would check into the green/red wire being grounded somewhere. I would suggest looking at the wiring that comes down from the top left corner as you face into the hatch from the back of the car.
That location is where I found my issue. I was perplexed for a while, when I grounded the green/red wire to the hatch, and the wiper would activate, but otherwise would not. When I looked into the aforementioned area, I saw that the green/red wire (and green/white wire too) was severed in two and sticking out of the rubber covering, which had gotten pinched somehow, by the previous owner. Once I soldered the wire back together, VOILA!, it was working once again. This was all after disassembling the wiper unit, cleaning, lubing, and general freeing up of the components. Since the washer tube is cracked, my guess is that it is the same old story of fluid getting into the unit and gunking it all up.
So, average person desperately looking for answers, there is something else to investigate. Clipped wires. I hope you find the solution to your answer soon.
Second owner of "Franklin", re-dubbed "The Pickle" by my comical family.
RiceChopper is offline   Reply With Quote
Page generated in 0.15558 seconds with 10 queries
[Output: 125.03 Kb. compressed to 103.60 Kb. by saving 21.42 Kb. (17.14%)]
