Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old August 3rd, 2009, 15:04   #1
unameiti'lltryit
TDI(s): 2003 Golf
Default Rear Wiper stopped working
The other day the rear wiper motor stopped working on my Golf. Is the fuse for the rear wiper in the fuse box on the driverís side? I checked all the fuses there and they are all okay. Any suggestions? I think that the motor might have just died.
2003 Golf - 195,000 km
Was an automatic now a manual!!!
unameiti'lltryit is offline   Reply With Quote
Old August 3rd, 2009, 15:15   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Plastic worm gear tends to strip on these, can you hear the motor turn over?
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old August 3rd, 2009, 16:36   #3
unameiti'lltryit
TDI(s): 2003 Golf
I'm not able to hear the motor turn over.
Old August 3rd, 2009, 16:44   #4
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Fuse Locations & Functions VW Jetta maybe Golf too
1. Washer nozzle heaters, glove compartment light (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, A/C, steering wheel module (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A)
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield washer pump, windshield wiper motor (20A).
25. Fresh air blower, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A). (if equipped)
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A)
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A)
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A). (if equipped)
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (w/ power windows), Trunk light, fuel door, Trunk lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A). (if equipped)
Fuse arrangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A). Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30 A)
I can't get the picture of the fuse panel to display, but look at the # 27 fuse to be the culprit maybe.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Old August 3rd, 2009, 19:02   #5
JASONP
JASONP's Avatar
Pull the hatch cover and check the harness plug for voltage while motor is activated.
Old August 4th, 2009, 17:38   #6
volkswheels
volkswheels's Avatar
Fuel Economy: 46mpg Winter/57mpg Summer w/Lucas Fuel Additive
Mine did that today on the way home from work in a freak rain storm!
volkswheels is offline   Reply With Quote
Old August 5th, 2009, 07:47   #7
Brian B
Fuel Economy: 3.7/5.1/6.5
See if the spray nozzle is corroded. This happened on my Golf and on my Jetta Wagon. I replaced the whole assembly both times.
Did you notice if it was spraying weird(not straight up) before it happened? Mine was spraying left and right for months before it finally quit on me. If you let it sit a long time without using it it may have rusted in one spot(seized). The motor is probably fine.
Brian B
Nehvrgoenbach
2003 Jetta Wagon TDI
GLI Lip, Tech9 Stage 1,
Autotech hollow rear sway bar, Aluminum Skid Plate
Ventectomy
Brian B is offline   Reply With Quote
Old August 6th, 2009, 13:26   #8
HandiDad
Hi, I am in the process of diagnosing the rear wiper on a 2002 jetta wagon. I have power to the plug and I cannot remove the wiper blade arm from the motor assembly. I was able to remove the nut, but it seem the wiper arm is froze to the wiper motor shaft. Does any one have any suggestion on how to remove the wiper arm.
HandiDad is offline   Reply With Quote
Old August 6th, 2009, 16:22   #9
JASONP
JASONP's Avatar
That shaft is a taper spline, you have the nut off so gently try to rotate the arm back and forth and is should come off, if not try a gear puller or some penetrating fluid.
Old August 6th, 2009, 18:03   #10
unameiti'lltryit
TDI(s): 2003 Golf
I got the cover off tonight to get at the motor. I unpluged the motor and when I turn the switch on I have power at the black wire and no power at the other three wires. When I turn the switch off I still have power at the black wire. Does that seem right?
Old August 6th, 2009, 18:39   #11
petea4
petea4's Avatar
TDI(s): '01 Golf GLS
Do you use it often?
Possible solution?
http://forums.vwvortex.com/zerothread?id=4001172
'02 Porsche 996 C4S
'08 Ducati Desmosedici RR '05 Ducati 999R
'05 Volvo V70 T5
'01 Golf TDI GLS
'72 Super - '52 Split - '65 Bus 21w deluxe
petea4 is offline   Reply With Quote
Old August 9th, 2009, 17:41   #12
unameiti'lltryit
TDI(s): 2003 Golf
Does anyone have wiring schematics for a 03 golf? I'm trying to troubleshoot the rear wiper that does not work now.
Old August 9th, 2009, 18:26   #13
Ksf
TDI(s): Zora
I had this happen to me with the last (sniff) TDI wagon. I found that the shaft failed because it had seized. The outer seal failed and let in the rain and corrosion resulted. I did not hear the motor once this failure happened and the gears (plastic) were still OK when I took the wiper motor apart.
What I found just before it failed for good (seized) was that the spray nozzle moved with the wiper arm, before it did not. Also there was residue inside where the arm shaft passed through the car.
Glad this is not like 55nm NPN material because being able to touch it is very satisfying....
05 Tora (T=B)
Ksf is offline   Reply With Quote
Old August 9th, 2009, 18:27   #14
MOGolf
MOGolf's Avatar
Yes, the black wire is constant system voltage (fuse 27) when the key switch is in the on position.
The brown wire is ground.
The green/white wire gets power (fuse 24) when the switch is put in the wash position.
The green/red wire gets grounded when the switch is put in the rear wipe or wash positions.
Unchained motoring
MOGolf is offline   Reply With Quote
Old April 28th, 2012, 09:23   #15
yvon g
i have a bad wiper motor as well. checked voltages and grounds as above all are good. i was able to remove nut and wiper arm, but what has to be removed to take out wiper motor. haven't ordered new motor yet, just looking to see what's involved in removing bad motor. thanks
yvon g is online now   Reply With Quote
Page generated in 0.17063 seconds with 10 queries
[Output: 123.16 Kb. compressed to 101.78 Kb. by saving 21.38 Kb. (17.36%)]
