Old April 5th, 2009, 18:18   #1
ocelot
ocelot's Avatar
Default How to flush coolant?
I searched and found bits and pieces of information here and there, and one guide specific to a Jetta. None were enough. What is the right way to flush the coolant in a B4? I mean drain it 100% (or as close to 100% as possible)?
I saw this in the Bentley Manual, and I'm seriously hoping there's another, easier way to get it all out:
ocelot is offline   Reply With Quote
Old April 5th, 2009, 21:10   #2
paramedick
paramedick's Avatar
If you find a way, let me know. I find that those clips are a birch (substitute different consonant) to get off and then reclip in place.
We slip the bottom hose loose from the radiator and get out what we can. We aid this by slipping the return hose off the coolant bottle and pressurizing the system with air.
We then put the hoses back in place. Fill the system with distilled water. Run the engine until the thermostat open.
Repeat as above until the drainage is clear.
An all TDI Family!!
Old April 6th, 2009, 14:48   #3
chittychittybangbang
http://www.myturbodiesel.com/1000q_h...olantflush.htm
Here's how I did it. Easy way and 100% drain - no such thing. Unless the coolant is bad, 90% drain is fine.
chittychittybangbang is offline   Reply With Quote
Page generated in 0.12313 seconds with 10 queries
[Output: 53.69 Kb. compressed to 48.26 Kb. by saving 5.43 Kb. (10.11%)]
