Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old April 14th, 2009, 06:08   #16
supton
supton's Avatar
Fuel Economy: 53/46/33
Glasspacks with a diesel? I would think that a bad thing, with the soot in the diesel exhaust. Maybe they don't have that issue--but the guy probably ran two just to make it quiet enough! If it were me, I'd think about running just one good diesel muffler, if I wanted it quiet.
Nice truck! Impossible to find up here, our New England salting schedule ensures we have a distinct lack of genuine old vehicles.
'04 Jetta Wagen 5spd GLS, 314kmiles, Koni Red's, SBC stage 2 clutch, VNT17, RC2 sold
'11 Camry base 6spd manual, 95k, wife's
'10 Tundra double cab, 4.6L, 95k, mine
supton is offline   Reply With Quote
Old April 21st, 2009, 13:05   #17
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
It is a resonator of some sort, don't worry about it. I own a 81 rabbit car (4 dr) a 81 rabbit (or caddy) truck and an 04 Golf. My brother owns a 80 rabbit truck as well. If you need anything more on this email me at tgott@hotmail.com as I don't know if I will check this often. My brother and I did tear apart a tan interior truck that rolled over and the dash and seats were very good shap. If you need them I could ask if what he would sell them for but shipping is a lot on those. As far as upgrades. I will over view them. This is a very good site to read and he has shifter linkage upgrades (the best out there) and leaf spring upgrades (the bushing part).
http://www.4crawler.com/VWpickup.shtml
The shifting problem that you have is one of two things. Your linkage is so worn out like mine was that it is hard to find 1st (I found putting it in 2nd then first works best and rolling helps) or your ajustment is off. If it is off you need to put in first gear and then loosen the attachment that goes on the long rod under the truck that has the balls for other linkages. push the part under the cab part of the shifter to the stoper (where you have to push down to get to reverse). and then tighten up and retry. It may take a few times. It helps to be on a car hoist with truck running and someone in the cab to make sure the adjustment is corrected. An exhuast system isn't going to help this truck out much unless you change engines (like I did in my car to a 1.9 turbo). Depending on your gear ratios you may not get very good MPG unless you drive about 50-55 as the trucks had lower gears trannys. I can get 52 mpg in my truck when going about 50-55 but if I go faster of stay in town I get what you are getting. My brother takes his on longer drives to work (30-40 miles) and has a different tranny and he gets about 55-58 mpg often. These can haul a lot in the truck (I got a king sized tempurpedic in mine) but the engines are only 50 hp. I would get from ebay or parts place a plastic cover that goes under the valve cover to prevent the engine from running away on its own oil as they were common of doing. DON'T put auto tranny oil in the diesel as a lubricant ever as that will swell the seals and once and the injection pump will leak then. Get some stanadyne fuel aditive for both vehicals as it helps with pump lubrication, increases cetane levels (like octane) and prevents gelling of fuel. The glow plugs are most likely slow glows but can be upgraded to a fast glow with the relay (you need the relay and plug speed to be the same). I would inspect your shocks as if they are original they are most likely bad. Check front and back wheel bearings (front-jack up truck and whiggle top and bottom, if it moves or there is a clunk clunk sound then replace, back-take off brake drum, make sure ebrake is off and add grease). Inspect CV boots and joints, carquest has a life time warranty on there trade in axles/cv joints if needed. Just make sure they don't bind in the hub if you do change. Get a Bently manual for sure but don't get the others as they are a wast of your time (I bought all of them). If your licence plate bulbs don't work. Unsrew the plastic casing and first check power to it (if no power, fix that and see if bulb works), if power there that a razer (wearing gloves) and split the clear and black plastic apart and replace the bulble and then tape together (don't glue or you have to try to cut it again). They don't make the replacement bulb casing so be careful. I almost got a ticket as mine weren't working.
Once you get the shifting linkages replaced and the cab fixed up some you will have a nice little truck to mess with. You may need to do the motor mounts as well as they can make your ride shake at higher speads if the mounts are really bad. Let me know if there is anything else I can help you with as I have take every nut and bolt of on both my rabbits. For piece of mind. Unless you have a recipt of the milage of when the engine was overhauled I would get the timing belt and tensioner replaced. Not to hard to do and I can walk you through that. You need a injection pump locking pin, a cam locking plate and a wrench for the tenchener pully (special one). You could mke the locking tools your self. That is just peice of mind for the cost (which isn't much) and they should be done at about 50K miles anyways. Good luck and half fun with this.
coalminer16 is offline   Reply With Quote
Old April 22nd, 2009, 22:22   #18
Jnco_hippie
Jnco_hippie's Avatar
Fuel Economy: his: 44mpg hers: 40mpg
I'll do the linkage adjustment on the truck friday, i hope, at school. we have lifts there.
I've seen that LUCAS is supposed to be safe fuel additive for diesel. I use it religiously in my motorcycle engine, and i can't help but believe, that it has prolonged the life of it. would you recommend using LUCAS for either of my diesel VW's?
I do believe that i would be quite interested in buying the interior that you removed from your wrecked vehicle. Could you post pictures of it here? I'll see what kind of shipping cost i'd be looking at. it might be worth it, just because, i've been looking for the dash, and haven't been able to locate one yet.
finally, I've seen that there is a turbo upgrade for the 1.6L engine in the truck. Do you have any experience with what this offers, or how much time and money i'm looking at? would it even be worth it in what kind of HP / fuel mileage increase that it might yield? we're not looking for lots of power or speed here. We are most interested in fuel economy, and to a lesser degree, a more "modern" highway speed.
thanks for all the info in your post. I'll go check out the link, and i've taken down your email.
His: BLK 2002 Jetta 1.9L TDI 5spd new inj. pump, starter, turbo, wastegate, MAF sensor, Timing belt, water pump, idler bearings, tensioners new glow plugs, New stage 2 clutch. 40 MPG (city) 52 HWY W/ 160,000 miles. **turbo trashed again! **
Hers: 1981 Rabbit TRUCK project car. just purchased 4/3/09. Block is cracked, replacing engine with NEW 1.9 conversion. due out of the shop any time now!
Jnco_hippie is offline   Reply With Quote
Old April 23rd, 2009, 12:16   #19
coalminer16
TDI(s): Golf 2004
I use stanadyne fuel aditive as it increases the lubication, cetane and gelling points and is the most advised one for the VW's as it is made by a injection pump manufacture. My CAT dealer sells it and most American diesels also advise using it. I will ask my brother about the dash and are you looking for seats as well or not? I would check your MPH readings at different speeds as it can be off and I almost got a ticket becuase of that. I would not recamend a turbo upgrade unless you are a wrench head as the engine isn't designed for it you have to make some adjustments and keep and eye on things or you could burn a hole in the piston and warp the head. The turbo engines had oil squirters for the pistons. Not to mention you may have more head gasket problems as you likely have the 11mm head bolt block and head and not the 12mm head bolt. The bolt is 1 mm wider and much longer and was to help prevent head gaskets from failing since the compression is about 23 to 1 in the engine (makes it easy to start cold). You should depending on the tranny that is in there (with the code you can find the gear ratios) be able to drive interstate speed. It may sound like it is going to blow but it won't becuase there is a govener in the injection pump that stops I think at 4500 rpm. When fueling up the truck it will take a while for it to completly fill as the tanks were the same on the gas ones so there fill tube is 1/3 from the top of the tank for a built in air cushion and it takes a slow bit of filling to fill the last 1/3 (3-4 gallons). So that may help you get the accurate MPG. Be careful filling to the top though as my breather lines leak if I go the last be so I have a running average. They did make toppers for these as well but are hard to come by. If you get a split window try to find the factory one as it has the 1 piece of sliding glass on the out side where the aftermarket (which they still make) have two pieces inside and can hang up on the seat head rests). Also seats from anything through the early 1990's will fit in there. I got my truck seats from a 1991 Jetta. My car has them from a late 80's car and my brothers are the stock ones. You can get map pockets with speakers from a later 80's car that screws into the door cars. Those are handy to have but you have to take the door cards off (get the tool to get the plastic clips out so you don't wreck the cards). You can velcro/screw in a cup holder in from of your shifter if you don't want to have a gauge pod in there. You just buy one from walmart with the coin holder and storage pocket and it fits. There is also a guy that makes wood ones that fit between the seats but you have to move it to use the ebrake. Let me know what ever else you have questions with as I know the 1.6NA in the trucks very very intimatly.
And the thing to remember to get really good MPG on this is driving speed and wind. These aren't the most arodynamic so the faster they go the more the drag (the drag coeficient is much higher then your newer VW's)
Old April 23rd, 2009, 12:32   #20
coalminer16
TDI(s): Golf 2004
I just looked at the pictures one more time and the comments below them. The engine may have been rebuild with just seals and maybe bearings if everything else tested fine. A complete rebuild doesn't have to be everything new but more everything is as good as new. New heads aren't as good as the original heads I have heard. And if you have a good body on the truck (shock towers and bottom of doors rust first) then it is worth $1500 even without an engine. And the horse power is 50. That is it. You can turn the injection pump up some to get some power and I have heard if done correct it will get better MPG as well as HP. If you are looking for more horse power for the truck those you need a different engine. You can put any VW diesel engine you want in there with some modification. I have a 1.9 turbo diesel in my car (75 horse) and it was as close to bolt on as you can get.
Old April 25th, 2009, 09:31   #21
Jnco_hippie
When i got it to school on friday, we got it up, and looked at the shift linkage. i found the long linkage rod, but did not know where to adjust at. do i adjust it at the engine end, or the shift tower end? also, the little "hollow" open sided "box thing" that the shift tower rides along for gear selection (under bottom of cab) seems to be quite shiny, and worn looking. we put it on the lift, got it into first, but never could figure out what kind of adjustment (or where, exactly) to make.
and yes, my wife is definately interested in buying whatever interior parts you have access to. if you could, just get some photos, so we can see if it is the parts we need (pretty much all of them) and what color, and condition they are in.
thanks again,
Old April 29th, 2009, 10:51   #22
Jnco_hippie
can someone tell me, for certian, how large the fuel tank is on the 81 caddy (rabbit truck) ?
i was very close to empty yesterday, when i filled up, it stopped at 9.2 gallons. is this a 10 or 12 gallon tank? someone told me they though it was 14, but i find that hard to believe, because if it is 14 gal, then i'm getting like 26 miles to the gallon.
Old April 29th, 2009, 16:57   #23
tdidieselbobny
tdidieselbobny's Avatar
I think it's around 10 gals.or so-I used to have around 400 miles to tank when I had my Rabbits-I think I still have a Haynes manual floating around-I'll check it if I can find it.
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 14k miles....'16 Kubota BX1870 MMM/FEL, 92hrs!
tdidieselbobny is offline   Reply With Quote
Old April 29th, 2009, 18:24   #24
tdidieselbobny
Just checked-Haynes manual claims 11.8 gals. fuel capacity....
Old May 4th, 2009, 11:49   #25
validius
Lacking in ZDDP
TDI(s): 1997 GTI TDI
Originally Posted by tdidieselbobny
No dealers-these are basically obsolete to them now.Find a good diesel mechanic(preferably one that works on foreign ones).A place that comes to mind for parts is PartsPlace in Auburn,Michigan.I have had good experiences w/them.They have a limited internet site- www.partsplaceinc.com -they have their catalog on the site.I always wanted a diesel Rabbit pickup-I settled for a gas one and it was the biggest POS I ever owned.
Parts place is a bunch of rude, overpriced shysters. I use them for nothing but a last resort.
1987 BMW 325IC, 115K miles. OEM+ or bust
RIP 1997 Golf 'GT' TDI 201,000 miles. TDI Engine/trans from "Rustetta"
validius is offline   Reply With Quote
Old May 8th, 2009, 14:13   #26
coalminer16
TDI(s): Golf 2004
Sorry, been away for a while for work. Your capacity is 15 according to the manuals but will hold 17 (just like the new cars you can squize in a couple extra gallons til you get it to the neck, a little harder as the pipe goes in the tank about 1/3 from the top as it is the same tank as a gasser). Depending on how you drive, how tuned and new/old the engine is and the tranny you may get only 26 mpg. I have gotten that before, but I can get 55 mpg as well. I will try to have my brother get you pics of the interior but they aren't the best on tech and I need your email for that as well. I think we even have the carpet for it but maybe not. And you should get more then 400 miles on a tank of fuel even if it is really bad. I get that with my rabbit car (10 gallon tank that can get the 11 or 12 gallons in it). You should average about 600-800 miles per tank. Parts Place isn't bad. They can be hard to deal with depending on who you talk with. They told me I have green stars next to my name as I have ordered so much from them but I have been burned a few times by them. If you use them have there part numbers they have in there book ready and don't have them attempt to find you the parts as thats how most of the mistakes are made. Ebay has a lot of parts for these so attempt to go through the 2500 ads under vw rabbit (that will get you the best results since it shares parts from the 4 door cars).
Adjusting the shifter. Get it to first gear and make sure it is first (some one in the cab, start and drive on lift if you have the lift that picks the frame and not the wheels). Then loosen the lever on the long rod while in gear but truck is turned off. Push the rod toward the box that you said was shinny, then tighten the lever while holding the rod next to the box. Make adjustments as needed depending on how loose the rest is. Replace everything on your shifter that is supplied in the kit on this web site (it is the best bang for your money trust me)
http://www.4crawler.com/Diesel/ForSa...tLinkage.shtml
Your motor mounts may be causeing some of the shifting problems to as if they allow the engine to move to much it moves the linkages as well some. Check the above web site for other info as he has loads of info on everything on a vw truck. The shinny box thing is just fine being shinny. That is your safety so you don't hit reverse without pushing down. So it gets shinny because everytime you put it in reverse it is rubbing it some. There is a rubber box that actually seals that up with a hole for the rod but those ALWAYS got ripped of and there is just a little bit of the rubber boot left on the rod that didn't get ripped off (it costs about $50 for the box if you wanted it). One more thing with the close to emty thing. You can drive a very long time on close to empty. That is a 2-3 gallons left at that point. If you are adventurous then you could carry some fuel with you and run the thing out. Make sure you have a flat screw driver to bleed the fuel filter and install a hand fuel pump from the tank. You can get one for about $12 from Walmart in the fishing section as it is a hand pump for a boat motor (brother and I have many miles on ours with pumps in the lines. That way when you change fuel filters you just have to pump up the line till no air comes out anyways.
Old May 13th, 2009, 22:20   #27
Jnco_hippie
Ok...
Here's what i've got:
I ran the rabbit truck down as far into the red (and past) what i figured was a true empty tank. When i re-fueled, it took 11.5 Gallons, and I had exactly 420 miles on the tank, that averages out to 36.52 MPG!! My Turbo Jetta (2002) only gets 38MPG!! Of course, i allways have my foot stuffed in it, just for fun. when i used to strech the mileage on the jetta, coasting, and easy peddle it, i would get about 41MPG. all of that is calculated inside city only.
SO, now i'm happy.
My muffler(s) fell off the other day, still attached at the manifold bolts (ouch!) I had to limp and drag it to school 1.2 miles from where it happend. scuffed up the tip, and second glass pack, but did not appear to break anything on the manifold. In true Texas style, i wired it all back on with baling wire and soft wire.
fixed a front driver side blinker. now no crappy tape holding it in. i rebuilt the lens with two bolts JB welded into the lens body (heads hacksawed off) and then inserted them into pre drilled holes in the body, fastened them with lock washers & nuts on the back side.
I'm looking for a good dent removal person, and then eying a paint job. We want solid white, with hot pink spray on bedliner. (it's a chick truck)
Still drives like a dream. best $1,500 dollars i've spent in years!
Oh, coalminer (and others) My email address is: JNCO_HIPPIE@YAHOO.COM
please send me any photos of body or interior piece that you may have for sale.
thanks yall!
Old May 14th, 2009, 20:24   #28
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
I have good luck with them. But i do use other sources first such as www.car-part.com and world impex and crazy rays. They sent me wrong filters once 5 or 6 years ago (and they would not pay for me ship them back. I still have them.I used one on my B5.5 Passat and plan on using others on my dad's Mk4
2003 Jetta GLS TDi TTbushings
2005 Passat GLS TDI Wagon Stone Henge Gray
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old May 15th, 2009, 11:34   #29
coalminer16
TDI(s): Golf 2004
You still should be able to get more in the tank as it is a 15 gallon tank unless it is dented. It just takes a bit of time to get the extra fuel in. I know my brother has some blinker lens if you wanted one with the bolts still in it (a parts car and truck later). I will give your email to my brother where the parts are.
Old May 17th, 2009, 01:25   #30
Jnco_hippie
the things we need most, right now, are:
tail light assembly or lens replacement for existing tail light assembly (both sides)
dash, or dash cover pattern for a form fit custom cover.
seats
timing belt cover
second hood (for mods)
manifold gasket kit(s)
dent removal & paint (going to be local, of course)
there's more, i'm sure, like the seatbelt on the passenger's side, hangs up constantly when you try to pull it over you, to lock it.
some of these things i've found possible answers to on EBAY, others i've not yet a clue.
I would like to take the existing tail light assemblies, replace them, then take apart the old, and make clear-cover red,yellow and white LED upgrades. Then, further into the resoration, we would re-install the newly re-manufactured and updated lights.
Page generated in 0.18983 seconds with 10 queries
[Output: 144.16 Kb. compressed to 122.32 Kb. by saving 21.84 Kb. (15.15%)]
