Old July 25th, 2008, 15:54   #1
Rover96
Default Strange boost activity.
After changing my filters I noticed that my boost gets to around 4-5 psi when I'm in 3rd or higher around 2100 rpm without my foot on the pedal. Shouldn't it be at vacuum if I my foot is off the gas?
Rover96 is offline   Reply With Quote
Old July 25th, 2008, 20:37   #2
tom167
tom167's Avatar
diesels dont create vacuum there's no butterfly valve on the inlet manifold
tom167 is offline   Reply With Quote
Old July 27th, 2008, 07:27   #3
Curious Chris
Fuel Economy: 47/42/38
At O% throttle, ie foot off the go pedal, one would expect the boost to drop to close to 0 psig. 4-5 psig seems a bit high assuming your car is stock and might point to turbocharger vanes sticking a bit.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Page generated in 0.13270 seconds with 10 queries
[Output: 52.07 Kb. compressed to 46.89 Kb. by saving 5.18 Kb. (9.94%)]
