Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old November 10th, 2016, 13:28   #976
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
Originally Posted by Gratefuldev View Post
The super common 03 ALH. It is indeed adjustable by VCDS. I suppose I should be asking if anyone has a VCDS in the area.
Yes
Mrrogers1 is offline   Reply With Quote
Old November 27th, 2016, 22:18   #977
Steve Addy
TDI(s): 97 Mk3
Someone stranded in Kearney, they're not from around there and have gone to Precision Import Repair. I'm about 300 miles away from him in Des Moines, is there someplace else that he should be going? I know nothing about what's available in NE.
Can someone please PM RayBrubaker if they have any info?It's his car but a friend is using it and the owner is currently out of the country.
Steve A
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old December 19th, 2016, 19:21   #978
twistedcricket
TDI(s): No TDIs
Default Turn in date selected
Jan 13th.
Really not thrilled, but in the end it's the best decision right now.
Maybe I can find an isuzu or cummins diesel to put in my Ranger....
Not my monkeys. Not my circus.
15 - VW Golf TDI SEL; Went back to VW
07 - Yamaha FJR; for when I need to speed
02 - Ford Ranger; for when I need to haul sh!t
twistedcricket is offline   Reply With Quote
Old December 22nd, 2016, 07:25   #979
Jettawolfs98
Jettawolfs98's Avatar
Fuel Economy: 42/38/30
Originally Posted by twistedcricket View Post
Jan 13th.
Mine is Jan 25th for both cars oh well it was fun, i guess I'm one of the butt heads staying with VW.
I got a 2016 Jetta Sport and my wife is getting a 2017 Beetle haha
Julio M.
No TDI's but who know this might change
Jettawolfs98 is offline   Reply With Quote
Old December 22nd, 2016, 11:33   #980
Mrrogers1
Thumbs up
Looking forward to servicing both of them.
Old December 23rd, 2016, 07:22   #981
Jettawolfs98
Totally 😉
Julio M.
Old January 8th, 2017, 10:05   #982
Buck_101
TDI(s): 2006 Jetta
Hello new here and need help. I have a 2006 Jetta Tdi with 135000 miles. The car was running normal with a egr that has been leaking for over a year. I changed my oil and fuel filter and manually moved the actuator on the turbo. I didn't adjust it just moved it and it moved hard then freed up. When i started the car it started hard pry due to the fuel filter change. I noticed driving the car i could hear the exhaust more then before and power was down a few week later. I put on about 400 miles a week. Then the weather started to get near 0 I added five gallons of number 1 from the same station i normally get fuel. The family and i went for a drive we put about 200 miles on and parked the car in the garage. The next day i started the car and got out to let it warm up and if ran for about 30 sec's and died. All the car will do is start and die runs maybe 5-10 seconds. If you heat the block is may stay idling no power at all putting it in gear will kill the motor. If it idles for a hour or so it will drive around the block but smoke with. You can smell the un burned diesel!
Now i have
replace the fuel filter twice thinking jelled its not
checked the anti shutter valve
took it to the big vw dealer in the big O and after a bill they told me its a flat cam. They wanted a small fee of 6000.00 BUCKS. The cam was needing replaced so i did it my self with a kit from Franks. Hes great to work with!
Now new cams same thing.
Unhook the vacuum line on the turbos accumulator and the car will run and idle so i broke the cam in. Right when you plug the vacuum line to the accumulator the car will die and smoke black. The accumulator rod doesn't have a chance to move before the car dies. Like its running off the air from the vacuum line. I was thinking stick veins in the turbo now but the level moves freely now. Could a plugged egr valve cause this. Im kinda lost with a diesel any help or ideas will be appreciated. Also not getting any codes.
Also in need for a vag-com to check my timing Frank will help over the phone. But i need it running first but i will make it right if i can use some ones tool.
Buck_101 is offline   Reply With Quote
Old January 10th, 2017, 14:59   #983
Buck_101
TDI(s): 2006 Jetta
Well the egr valve was stuck open... Still need a vcds if anyone in the area has one.
Old January 12th, 2017, 15:02   #984
Mrrogers1
I do have one BUT I'm crazy busy and not even sure when I could connect with you. I live in Omaha, work in Lincoln and the shop is also in Lincoln. How quickly do you need assistance?
Old January 15th, 2017, 15:23   #985
twistedcricket
TDI(s): No TDIs
Turn in completed... bittersweet.
Old January 24th, 2017, 07:22   #986
Buck_101
TDI(s): 2006 Jetta
Default Pm sent
Email sent
Old January 24th, 2017, 07:32   #987
Buck_101
TDI(s): 2006 Jetta
Default Pm sent
Email sent
Old January 26th, 2017, 19:21   #988
Jettawolfs98
It was a sad moment, oh well .
Sent from my iPhone using Tapatalk Pro
Julio M.
Old March 25th, 2017, 16:11   #989
Jettawolfs98
Hey guys I wonder how many people are still coming haha
Julio M.
Old March 25th, 2017, 16:13   #990
Jettawolfs98
Just a heads up, I got a set of OEM Bi-Xenon headlights for sale from my JSW including the kufatec wiring. If anybody is interested send me a message, I will post it on the classifieds but here is a picture.
Julio M.
Page generated in 0.17173 seconds with 10 queries
[Output: 127.34 Kb. compressed to 106.09 Kb. by saving 21.25 Kb. (16.69%)]
