Old February 10th, 2008, 09:10   #1
GotEuroCorrado
Default Where did my first and reverse gear go? A transmition pulling story.
so over the past week i was have some issues shifting into 1st and rev and could not figure out what was going on. i was fine in the higher gears but thats because im used to rev matching to make my shifts smoother. on Thursday i flat out could not get into first/rev unless i put the car in gear when off. after adjusting the shifter linkage a million times, installing a VF dogbone (DONT EVARRRRR DO THIS IN A TDI), and bleeding the clutch slave/master i still could not get anywhere. last thing i thought it could be was the pressure plate, perhaps one of the straps broke loose and was causing the crazy vibration when i let out the clutch. i picked up a new vr6 clutch and pressure plate to swap out and began pulling the trans. once i got it out i found the pressure plate was fine... the clutch fork was to blame. it was cracked and bent back BAD. i pulled out the sachs stage 1 disc and stage 2 pressure plate and put the new vr6 stuff anyway. once together everything was perfect and my foot damn near went though the floor because the stock vr6 pressure plate was SO MUCH lighter then the resprung version i was using.
ACS TDI SPECIFIC MAINTENANCE AND REPAIR IN HATBORO PA (267)317-8229
$600+/- ALH/BEW/BRM/BHW TIMING BELT KIT INSTALLED NEAR PHILADELPHIA !
used parts FS: http://tinyurl.com/zfdjgyh
smoking deals on TIMING BELT KITS: http://tinyurl.com/ov57jfl
GotEuroCorrado is offline   Reply With Quote
Old February 10th, 2008, 09:38   #2
tomo366
TDI Lifer
tomo366's Avatar
*** is a transmition???
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old February 10th, 2008, 10:04   #3
jsrmonster
Veteran Member - TDIClub Enthusiast
jsrmonster's Avatar
glad you got it fixed. I drove this car and I must say, that was one heavy clutch pedal, it's no wonder it broke. Get the next fork reinforced in the webs.
Jeff
15 Golf SW DSG, 00Jetta 6spd race, 99.5Jetta Rocket ARL-PD150 6spd 2260, 2003.5 5.9L Cummins QCLB 4x4 Blue Monster, 00Passat1.8T, other tdi's: 97J, 98J, 99.5J2x, 00-C5 6spd - EFILive, HPTuner, Diablo Sport!
Never argue with an idiot.They will just bring you down to their level and beat you with experience.
The beatings will continue until the morale improves!
Good judgement comes from experience, and experience comes from bad judgement !
"DIESEL TUNING PROFESSIONAL" 1-5-3-6-2-4=;-)
jsrmonster is offline   Reply With Quote
Old February 10th, 2008, 10:36   #4
shortysclimbin
shortysclimbin's Avatar
Doesnt a company make a reinforced webed clutch? I cant remember where I saw it. How many miles on this setup btw? It would be good to know for those of us that might be running the stage 2 parts.
shortysclimbin is offline   Reply With Quote
Old February 10th, 2008, 10:52   #5
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
those wheels are HOT!
orion2.0 is offline   Reply With Quote
Old February 10th, 2008, 14:20   #6
Chemboy
I had a friend drive my car with the VR6/G60 stetup and he said it's really more like a clutch button!
-Andy
Chemboy is offline   Reply With Quote
Old February 10th, 2008, 19:02   #7
GotEuroCorrado
not many miles on this setup, maybe 20k on the clutch/pressure plate. i could have put them back in but i opted for the regular stuff so the fork wont crack again.
Old February 10th, 2008, 19:44   #8
Rub87
Like the rimms dude!
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old February 10th, 2008, 21:15   #9
GotEuroCorrado
thanks a lot,
here are some more pics in color
Old February 11th, 2008, 09:29   #10
herc269
Fuel Economy: 52mpg
The car is very nice. Do you have any rubbing issues with the tires?
Thank You for re-affirming that I'm not going crazy. I am having the same issue with my 1998 Jetta TDI. It is very difficult getting it to go into 1st gear and reverse. At this point I always go into 2nd then into 1st at a stop light and reverse is just as difficult, I think I have it in and when I gently release the clutch she'll move forward. Was it difficult changing the Fork?
herc269 is offline   Reply With Quote
Old February 12th, 2008, 06:02   #11
droppedjet
Fuel Economy: 45/50
Those are RS4 wheels right...damn that setup is sick
//M3 FTW!!!!!!!!
droppedjet is offline   Reply With Quote
Old February 12th, 2008, 21:49   #12
GotEuroCorrado
i have a lil rub in the front over some high/low rolling bumps but otherwise thats daily driven right there. the wheels poke because of the 20mm adapter i run since the wheels are 5x112. i recently got a 15mm adapter which should help even more (i hope).
Page generated in 0.14427 seconds with 10 queries
[Output: 104.95 Kb. compressed to 87.90 Kb. by saving 17.05 Kb. (16.25%)]
