Old February 19th, 2007, 21:57   #1
tonywong
TDI(s): 2000 Jetta
Default where to get motor mounts?
Although clutch and flywheels threads are always up but there isnt much information about motor mounts. One of the clutch threads had somebody recommending that you replace the motor mount when u change the clutch and flywheel. Are motor mounts just bolts or an expensive part? Because i looked into it at ECStuning site and there is this complete engine mount package for like $500+. So school me on motor mounts and if you could post a website where to get descent mounts that would be great. Thank you.
tonywong is offline   Reply With Quote
Old February 20th, 2007, 00:13   #2
doc_m
doc_m's Avatar
TDI(s): None
all you would need to do is have the motor mount bolts that would be removed replaced not the mount itself.
Do work on cars like intake cleanings, nozzle swaps, brakes etc.... Hex usb + can now
2009 Jetta TDI Comfortline with ESP and beige leather interior. Evolution Imports Osiris Skidplate.
So far just over 10,200 kms on it
doc_m is offline   Reply With Quote
Old February 20th, 2007, 06:46   #3
Drivbiwire
Zehntes Jahr der Veteran
If you have over 200,000 miles then replacing may be a good idea, Each mount (2 required) is around $100.00 at the dealer.
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old February 20th, 2007, 06:55   #4
Drivbiwire
http://www.worldimpex.com/parts/germ...nt_281300.html
$60.00 Engine side
$40.00 for the transmission side (manual)
DB
Old February 20th, 2007, 06:56   #5
cage
Depending on the age of your car... They are just rubber bushings which do harden and crack with time.
While they won't hurt to reuse you will notice less engine noise inside the car with new ones.
cage is offline   Reply With Quote
Old February 20th, 2007, 06:56   #6
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
DB
Could you expand on this? Are you talking about the top part of the pendulum mounts that suspend the engine/transmission ? What about the lower part of those mounts (brackets) that bolt onto the engine (They can get their threads stripped after a while...) ? Ditto for the lower rear mount... Are these all to be renewed on high-milage vehicles ??
Yuri.
ymz is offline   Reply With Quote
Old February 20th, 2007, 07:04   #7
Drivbiwire
The upper mounts have rubber supports, time will cause them to sag and not absorb vibration...common sense says to replace after awhile.
The lower side mount can be re-used several times. As long as bolts aren't re-used, over-torqued and you use NEW OEM BOLTS that have the thread protection coatings I see no reason why the mount can't last 5+ timing belt changes.
DB
Old February 20th, 2007, 08:27   #8
ymz
...sigh... I guess on my next timing belt change (oh... about 14 months away... should be up to 286,000 miles by then) I may as well replace the mounts... and the cam followers... and...
Thanks,
Yuri.
Old February 20th, 2007, 18:39   #9
tonywong
TDI(s): 2000 Jetta
another forum told me to buy Dogbone motor mounts which only cost $40, not $100 mounts. so which one is it?
Old February 20th, 2007, 18:46   #10
doc_m
doc_m's Avatar
TDI(s): None
I saw that post on the dov definatly take the advice from drivbiwire before anything from there. They are saying install the poly bushings which from what I have read are not a good idea on the tdi as the transmit to much vibration.
Old February 20th, 2007, 19:18   #11
I am starting to think that replacing the mounts after 150-200K might be a good idea. I can't imagine that any of the rubber parts of the car should be expected to perform at their best after this much time. I'm going to renew my mounts at my next TB change (scheduled for 180K).
Having said this, if it ain't broke....
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old February 21st, 2007, 09:24   #12
tonywong
TDI(s): 2000 Jetta
yea i surf the DOV site a lot but OF COURSE i'm gonna listen to the ppl here because u all drive diesels like i do. most local ppl here in Vancouver drive 1.8T.
Page generated in 0.15578 seconds with 10 queries
[Output: 103.20 Kb. compressed to 86.45 Kb. by saving 16.74 Kb. (16.23%)]
