Old March 20th, 2017, 17:22   #1
TDI_Michael
TDI(s): 01 Golf GLS
Default Where do you splice in a new ABS sensor?
Changing out struts this weekend and I tore the ABS sensor wires from the connector head on the passenger side of my 01 Golf. Looking at pics of replacements it looks like they have alot of wire, well past where it goes into the wheel well. I pried open a hard plastic protector piece by the strut on the fender well under the hood and I can see the wire passes here before going into the dash area. I am thinking this may be the best spot but was curious where others who have done this have made the splice.
TDI_Michael is offline   Reply With Quote
Old March 20th, 2017, 19:37   #2
Dieselmonkey02
TDI(s): 02 jetta
Fuel Economy: 48-50 avg. 44 lowest 54.6 highest
Could just cut both sides and get some Bosch connectors and redo it that way.
Dieselmonkey02 is offline   Reply With Quote
Old March 20th, 2017, 19:54   #3
TDI_Michael
TDI(s): 01 Golf GLS
There is no wire on the connector end that I can see at least. The connector stayed attached while the wires pulled out of it.
Old March 20th, 2017, 22:37   #4
bbarbulo
if you look at my thread in the Golf Pictures forum, I did the same boo-boo. Just soldered it up and that was it. no need to go and spend if you can repair to an acceptable level. you need to depin the connector, then file the pins to reveal some copper (so you can solder), then solder the wires back on the pins, and that's it.
FOR SALE!!00 TDI Golf 5spd, satin silver GTI tails w/ 5 light brake mod 20AE springs Bilstein SS shocks 17 Long Beach Altas skid plate clear repeaters short antenna Clarion deck G60/VR6 clutch
bbarbulo is offline   Reply With Quote
Old March 21st, 2017, 00:38   #5
TDI_Michael
TDI(s): 01 Golf GLS
I wish I would have seen your post earlier as I found a new one on ebay for $50 bucks VW brand. I hated spending that much but new ones were almost twice that. Also for others that this happens to I see they sell the connector head on idparts for around 10 bucks if that is damaged. I appreciate you directing me to the Pictures forum, I never look there but they have some great stuff. When my new cable arrives I guess I will try and splice it in but while waiting I may take the connector head apart to get a better idea of whats involved. Thanks for the post
ABS front right ABS sensor scha0786 VW MKIV-A4 TDIs (VE and PD) 17 August 10th, 2017 12:27
HELP! abs sensor Skullbag VW MKIV-A4 TDIs (VE and PD) 4 August 30th, 2012 21:37
abs sensor dan arc VW MKIV-A4 TDIs (VE and PD) 6 June 6th, 2012 21:30
Why would someone 'splice' into the 02 sensor Line rixtory TDI 101 7 September 24th, 2006 10:21
ABS sensor Skimax VW MKIII-A3/B4 TDIs 0 August 1st, 2005 11:32
Page generated in 0.15375 seconds with 13 queries
[Output: 67.16 Kb. compressed to 59.52 Kb. by saving 7.64 Kb. (11.37%)]
