Old July 23rd, 2016, 09:45   #16
Funguy
Fuel Economy: 47 mpg
Thanks. I have a scan gauge from the ALH and haven't gotten around to putting in this car. Great idea to get that done and montior the boost.
Funguy is offline   Reply With Quote
Old August 4th, 2016, 17:00   #17
Funguy
OKAY folks, I just got the car back again from the dealer. This time they re-acclimated the MAF to the computer even though they didn't change the MAF. They also loaded the latest software for the MAF system.
The regional tech guy showed up and asked them a bunch of questions about whether they did certain things or not. The crew at the dealer were not aware of these things (whatever they were) since there were no instructions to do them in their manuals. SO the regional guy told 'em what to do and there is about 100 miles now with out the MIL light coming on. I will not be sure it is fixed until problem free for at least a week.
If you are having this problem and want more info on what they did to my car call the service dept of Gephardt VW in Boulder Colorado 844-921-5705 I will post again if this fix fails! The courtesy at this shop has been first rate. I will not fault them for not being able to fix the car since the other three people in USA and Europe with this problem were unable to find solutions either. Keep your finger crossed thanks
Here is the verbatim from the receipt "Relearn procedure for the mass air sensor not performed after last repair. Procedure is not listed in repair manual or scan tool. Procedure came from VTA. Opened BTA KP-44281. Cleared code and performed test drive with scan tool to capture readings. Test drove 10 miles. Test drove like vehicle BIN FC048085. Reading are the same at idle and while driving. Performed relearn of mass air sensor per tech line."
Old September 4th, 2016, 20:49   #18
Funguy
Default Fail, Fail, Fail
Amazing, after a high speed 1,000 mile trip to Utah and back and a month of commuting back and forth to work......You guessed it, those two codes are back. A month to the day it looks like in fact! Really thought I had this licked.
I am ready to perform an exorcism at this point. Where can I get holy oil and blessed coolant?
I was going to keep this car and sell back the sportwagen but at this point I begin to think that BOTH cars will go back to VW. I have watched the "What would you replace your car with thread" and don't see anything that will suit me like my diesels do.... sigh
Any new ideas out there on these codes?
Old September 7th, 2016, 20:10   #19
Funguy
Default Mr. Scott?
The dealership has thrown in the towel which I respect them for. They are calling in an engineer which I am told are the highest trained mechanics that VW has. They train in Germany. He or she will be in Boulder tomorrow to look at my car.
I am perplexed that they haven't thrown a new MAF sensor at the car. Cheap enough and easy enough to do but VoA is telling the dealership NOT to change the MAF. If a new MAF doesn't fix it then I have wonder about the computer? Perhaps the engineer will decide to try a MAF
Interestingly the MIL, which has been on since Sunday morning, did NOT come on this morning when I started the car and drove it to the dealer. I assume they were still able to pull the codes since they are holding the car for the engineer..
Old September 8th, 2016, 18:56   #20
Funguy
VW of America has given up on this problem. My car was returned to me today with the acknowledgement that they can not fix it and the promise that VW is working on an update to address this problem that is popping up around the country.
They do not know when this update will be available. I am told to simply drive and let the dealership know if and when the mil reappears.
Of course I am not happy about this but the Boulder VW shop has treated me EXTREMELY well. I don't blame them for not being able to fix the car since they have been in contact with VoA and they can't figure it out either.
Old February 26th, 2017, 11:56   #21
Funguy
SOLVED?!
For anyone still having this code problem: I was told by the dealer that the first phase emissions repair which they did yesterday, will repair this MIL problem. I think they may be right because the modification loosens the OBD parameters to throw a code when OBD detects an emissions system hiccup. I won't believe it for sure until I drive 5000 miles without throwing the POOBD P00BD code, but I am very hopeful.
Meanwhile: I've only driven 30 miles since I got the car back from the emissions mod yesterday but it feels the same to me right now. If you have a 2015 car you might want to consider the fix strongly. For me I just couldn't get my head around a gasoline car.
BTW: I feel I have been treated very well by the service dept at VW in Boulder Colorado
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent Fuels & Lubricants 4 February 21st, 2011 04:21
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent VW MKIV-A4 TDIs (VE and PD) 5 February 18th, 2011 14:39
P0226 Throttle Pedal code went away and was replaced with a glow plug code. Fixed. thordehr VW MKIV-A4 TDIs (VE and PD) 0 June 6th, 2010 21:11
Airbag fault code together with low voltage code msa6 TDI 101 5 April 24th, 2008 13:38
Vag com code 00527 - code reader P1161 tdidieselbobny TDI 101 4 December 11th, 2006 13:07
Page generated in 0.12387 seconds with 13 queries
[Output: 78.12 Kb. compressed to 68.62 Kb. by saving 9.49 Kb. (12.15%)]
