Old February 5th, 2017, 18:20   #1
Fuel Economy: 40-45 mpg
Default PassKey Failure error on display
Since I am now out of warrantee, this concerns me. I entered my car, went to start it up, and as I'm pushing the start button, the display reads something to the effect of PassKey Failure. Now, the car started without any hiccups but it leaves me with some concern. I replaced the battery in my key fob, just to be safe, but I wanted to know if anyone else has encored then message. I was unsuccessful in finding any other threads on the subject. Thanks for any input you can offer.
Drive safe.
j2112morris is offline   Reply With Quote
Old February 6th, 2017, 04:12   #2
What is PassKey? Are you referring to the KESSY system?
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old February 6th, 2017, 07:29   #3
I had an error the day that I went to turn mine in. It said key not in range. I held the key up the the steering column and it started. The JSW without KESSY did something similar. I disconnected the battery and it worked fine after that.
BarryT82 is offline   Reply With Quote
Old February 6th, 2017, 08:39   #4
Gadget Guy
compu_85's Avatar
It's most likely the battery in the remote. Scan with VCDS to be sure.
2013 Fiat 500e. 22,000 miles.
2014 Cadillac ELR. 23,000 miles.
2012 Passat SE TDI DSG. 112,000 miles. Factory Alarm, LED tails, Memory Seat, HIDs 38/48 MPG. Buy it from us!
2004 Touareg V10 TDI. 165,000 miles.
99.5 Jetta "GLX" TDI. 310,000 miles. Half way there!!! Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is online now   Reply With Quote
Old February 6th, 2017, 15:29   #5
TDI(s): 2.0 CR
if he open car by hand (not remote button) battery is ok, also cluster will show " Low battery"
HOT HOT Cruise Control via MFSW HOT HOT
Spacewalker is offline   Reply With Quote
Error code P0605 - PCM Read Only Memory (ROM) Error Marin TDI 101 18 August 22nd, 2012 04:48
Display MPG on clock display on instrument cluster? daniel_mad Ontario 3 May 17th, 2011 20:16
MFD display add on screens? like remote display for radar detector? PlaneJob VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 April 30th, 2010 06:16
error 109/ Mechanical failure fuel cut off valve. jfjjr VW MKIII-A3/B4 TDIs 4 November 4th, 2005 19:36
OBD Info on Climatronic Display (AirCondicioning display) manuSpain VW MKIV-A4 TDIs (VE and PD) 0 May 28th, 2001 14:24
Page generated in 0.14970 seconds with 13 queries
[Output: 69.65 Kb. compressed to 61.75 Kb. by saving 7.91 Kb. (11.35%)]
