Old February 2nd, 2017, 05:08   #511
nord
Correct! Brain fart I guess. My point, though, stands. The entire system needs flushed and it's almost impossible to do without pulling a lot of plumbing on one hand or flushing per my method on the other.
On the subject of an orange coolant tint, this is why I stressed cleaning the reservoir. Even a slightly contaminated and stained reservoir will cause the pink to go slightly to the orange at least to the eye. Best to siphon coolant out of the tank into a clear glass container to have a look.
So once again... Any orange discoloration is an indication that the system is contaminated. This is the reason the car must be driven for a couple of miles while up to operating temp between flushes until only clear water remains in the system. Only then will the coolant be a bright pink color and not take on an orange tint for the final fill.
Given that there is no easy way to disconnect and flush the system from the bottom side of the car and that we're dealing with two distinct systems sharing the same coolant, I tend to favor the topside flush. I tried the bottom flush on one of our cars and about the best I can share is that I wore and tasted a lot of coolant, and that the flush was unsuccessful. It was very frustrating at minimum.
Topside was quick and easy by comparison.
One last point... The vacuum causes more turbulence than merely cycling clean water through the system. It seems to dislodge more contamination than other methods and allows the clean water to suspend these particles for removal. Water will probably be heavily contaminated for the first two cycles. The third will often be clean. The reservoir will become badly stained and will need cleaning after the last cycle of clean water.
nord is offline   Reply With Quote
Old October 12th, 2017, 07:15   #512
bfbay
I'm on my second replacement core, and I still don't think things are right. I had the core replaced for the second time 3 weeks ago. Took it back to the dealer after 1 week because I was still getting low heat out passenger side after the core replacement. They ended doing something with the egr cooler and flushing the cooling system. I think they replaced the core without getting the junk out of the cooling system first..
Anyway, I'm getting heat, but the temperature gradient from left to right is 170, 147, 126, 110 when running heat with high fan out of the vents. Car was heated up, vents were all open.
What is the normal temp for the passenger side vent when running highest fan setting and hottest thermostat setting?
bfbay is offline   Reply With Quote
Old October 13th, 2017, 19:42   #513
bustNfuel
bustNfuel's Avatar
Fuel Economy: 39-42
Mine was replaced under warranty about a year ago.
The temps from my vents at full hot, fan on high and engine up to normal operating temp and outside air temp in the upper 70's just the other day:
160/160/150/130
...using a Raytek hand-held infrared thermometer.
'13 Passat SEL ● TDi DSG ● 60K+ miles
bustNfuel is offline   Reply With Quote
Old October 14th, 2017, 05:19   #514
Rico567
Had mine replaced last winter under the extended warranty after a trip to VA where the passenger side was somewhat chilly. If there are any problems again this winter = another core.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old October 14th, 2017, 07:37   #515
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
You should be able to get at least 150F from all of the vents at full operating temperature.
Trusted TDI Mechanics Map || TDIClub Chat
Old October 16th, 2017, 07:29   #516
jrm
Fuel Economy: 42/52
mine is for sure plugged, I replaced the coolant via the shop vac method Nord did, helped a bit but not much. On a crisp day mine are 160,98,52,40 and wont de-ice the window on the passenger side so when driving in snow, we turn the heat completely off so the window freezes and the snow will not stick to it. works great, buuuut wife isn't on board and wants a new Toyota hilander
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old October 17th, 2017, 09:08   #517
06bluebeetletdi
Mine is being replaced today!
06bluebeetletdi is offline   Reply With Quote
Old October 23rd, 2017, 02:36   #518
767wrench
Fuel Economy: 37-43
One more factor in my decision to abandon ship! I knew my car was on coolant system life support. I had installed an filtration system and green coolant and it still was turning dark orange although no more sediment and I had good heat. But there were so many coolant hoses between the factory ones, frost heater, and filter that things were chafing and I was constantly inspecting for chafed lines.
12' Passat SE TDI; Cr 170 Turbo, Stage 3.5 malone, dpf, egr, muffler delete, traction control delete button, Sachs SRE Performance clutch with DMF, KONI Sport suspension, H&R lowering springs, Fluidampr by INA engineering, mini train horns, HID 10K projector headlights with LED DRL, painted brake calipers, ID parts winter front, frost heater, 19" Enkei Raijin - GONE TO BUYBACK
767wrench is offline   Reply With Quote
Old November 9th, 2017, 11:26   #519
danko0
TDI(s): Passat TDI
HI guys, It`s really a long topic, so I believe it`s best to ask I`m having Passat b7, with the same issue as all do no heating, so I`m pretty sure it`s the heat core I need to replace. The question is do I need to disassemble the dash ? or the replacement is done from under the driver dash part.
P.s. for some reason I`m not seeing the pics in the topic, so please excuse me if it`s shown there.
Thanks in advance.
danko0 is offline   Reply With Quote
Old November 10th, 2017, 17:12   #520
Good Ol' Boy
VeeDubTDI's Avatar
Thanks in advance.
I don't know if the B7 (European Passat) is laid out differently than the NMS (North American Passat). In the NMS, heater core access is right next to the accelerator pedal.
Old November 10th, 2017, 19:45   #521
tdiatlast
^^^and...has the real B7 been affected by the heater core issues???
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old December 18th, 2017, 06:30   #522
Bearsvw
Had the heater core replace January of 17 it worked great last winter but now no heat on passenger side again
2013 passat highline loaded, lowered
2012 ram sport crew
Bearsvw is offline   Reply With Quote
Old December 18th, 2017, 08:51   #523
740GLE
Prob not due to the fact they don't have to meet the same emissions (NOx ) requirements and they probably don't use and abuse the coolant system as much.
740GLE is online now   Reply With Quote
Old December 19th, 2017, 15:27   #524
Bearsvw
Well heater core replaced today again. I have heat again. They ordered the parts for the add blue tank. It's being replaced next.
2012 ram sport crew
Old December 28th, 2017, 01:28   #525
Bearsvw
Heat is now gone again. It's worse than before the heater core replacement last week.
2012 ram sport crew
Rusty coolant and clogged heater core sweetlou132 VW MKV-A5 Golf/Jettas 24 March 5th, 2017 16:13
'10 GOLF TDI, NO HEAT (passenger side), Driver side gets HEAT? Clogged heater core. RomanL VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 March 23rd, 2015 10:23
Heater Core/Blend Door/Heat Problems - Noise from Dash tug VW B5 Passat TDIs 2 April 9th, 2012 09:41
Heater core? Very little heat IanFlo TDI 101 2 October 2nd, 2007 17:09
Heat still smells like antifreeze when new heater core installed?? Magic99 TDI 101 2 June 12th, 2007 12:07
Page generated in 0.17869 seconds with 14 queries
[Output: 132.40 Kb. compressed to 111.39 Kb. by saving 21.01 Kb. (15.87%)]
