Summerheat
Hello, I'm new to these forums, please let me know if I should post this elsewhere.
I have a 2009 jetta tdi sportwagen (cbea engine) with over 186k km that has not been driven in over a year. My parents had some difficulties with the buyback and its looking like they might ending up having to keep the car.
The problem is that after 8 years of reliability, the German unreliability stereotype has reared its ugly head. Here's a quick rundown of the stuff the car definitely needs.
1. Rear calipers need to be replaced/rebuilt. They work fine but the rubber's on the pistons are shot.
2. Rotors all around have become extremely rusty from sitting
3. Front drivers side coil spring
4. Dual mass flywheel for the DSG
5. A DSG service
6. Balance shaft module repair/delete
7. Timing belt
8. Filters all around
Is it even worth fixing? I really like the car, but I would not feel comfortable driving it around until all these things have been addressed.
Over a year ago, the low oil pressure light started flashing and chiming right as I got to the bottom of my street, so it was not driven very far. Looked it up and figured it must be the hex shaft. So I dropped the pan and replaced it, it was indeed stripped (I believe it was only stripped at one end, but I cannot remember. I have to find the old shaft). Put everything back together and took it for a test drive (<10km) and all seems to be well.
However this issue is bound to come up again, likely in a less convenient location, so I am looking for a permanent solution. What is the official Volkswagen fix for this problem? I've read about the bsm delete and am worried about snapped crankshafts and some other issues that have been reported. How difficult is it to install the bsm delete kit?
Interestingly enough, the coil spring snapped during this test drive. I heard some clanging and I nearly had a heart attack, thought i forgot to bolt something down, or I forgot some tool.
When I parked the car I noticed a faint knocking sound while in park, that goes away when put into gear. Typical signs of a bad dual mass flywheel. Bad luck I guess. Anyone replaced one before? How difficult would it be? Do I need to buy any specialized tools for any of these jobs?
Just looking for some more input, help me wrap my head around the situation.
Thanks in advance everyone!
5. A DSG service
7. Timing belt
