Old December 5th, 2019, 07:00   #1
Fastbird
Default Cold Weather Hesitation/Stumble/Knocking, Torque Difference, NO CODES
Same issue I've been dealing with for going on my third winter now. Cold start only, very pronounced diesel nailing, and around 1750 RPM stumbling and hesitating, until engine starts warming up.
Car is NOT hard setting any codes. VCDS will show a pending code for "torque difference" on Cylinder 2 (I believe, been a while since I've looked at it). Symptoms are pointing to a failing injector like many other people have experienced.
HOWEVER......the local VW dealership says their computer shows no pending codes and refuses to even try to diagnose further. They test drive and say it's "normal" or check the oil and say it's slightly overfull and causing the problem.
So my question is......what is the threshold for getting that Torque Difference code to hard set? I've driven the car and had the stumbling so bad the car wouldn't accelerate anymore and no code ever hard set, no check engine light.
Fastbird is offline   Reply With Quote
Old December 5th, 2019, 11:44   #2
22eco
TDI(s): 13 Passat SE
It sounds like the injectors are going bad or at least one. I have dealt with this issue directly. let me guess the issue is only when you first start the car? The dealer cant replicate the issue?
Drop your car off the night before the appointment, leave a note in the car stating for a technician to start the car and drive it right away. They will feel the issue then figure it out from there.
22eco is offline   Reply With Quote
Old December 5th, 2019, 12:10   #3
Fastbird
Done this. They can never seem to replicate or tell me the hesitation/stuttering is normal as it warms up. The techs are full of.....excrement, even the head tech who said there's no way it's an injector, they don't act like that when failing. Whatever. I'm just trying to get the dang code to hard set so their hand is forced into fixing it under the warranty. Problem is they're the only dealership in the area.
Old December 5th, 2019, 19:13   #4
06bluebeetletdi
Drop the car in the dealership parking lot the night before, do not leave your keys, go back in the morning. Insist someone drive it with you with the scan tool connected.
06bluebeetletdi is offline   Reply With Quote
Old December 6th, 2019, 08:39   #5
22eco
That’s what I did, I took it to the dealer like 3 times before they figured it out.. You have to emphasize that they drive it right after they start it..
Old December 10th, 2019, 10:19   #6
rmilchman
I'm having the same hesitation issue. Dealer told me there are no codes and their is nothing they can do until a CEL comes on. I opened a case with VW, and the car goes back tomorrow. There seems to be several threads around the same topic, all of which point to the Injectors.
rmilchman is offline   Reply With Quote
Old December 10th, 2019, 11:05   #7
KERMA
KERMA's Avatar
You won't get a code to set and here's why
The applicable diagnostic routines in the ecu that relate to this condition are not in effect (aka "released") until the coolant temperature reaches 50C. So there won't be any codes set in the ecu when the car is first started and the engine is cold.
You will have to wait until the injector worsens enough so that the torque difference for the affected cylinder is outside the "accepted" tolerance band so that the ecu recognizes the condition while the diagnostics are operating.
If you want to diagnose which cylinder is unhappy, you will need to find the "inner torque" or "internal torque" in advanced measuring blocks, and compare the readings between cylinders. Should be pretty obvious.
Sadly, until there's a CEL, the injectors are technically "within spec", even though teh nailing is irritating.
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Niels Bohr
KERMA is offline   Reply With Quote
Old December 10th, 2019, 11:08   #8
rmilchman
I'll give this information to the dealer when I drop the car off. I'm sure they won't be happy about me doing so.
Old December 12th, 2019, 07:24   #9
rmilchman
Now it's time for the real games to begin. Got a call from the dealer. After working with a VW tech on the phone and running tests the tech recommendation the outcome is to replace the 4 injectors. Since there is no CEL, I'm being told they don't think warranty will cover it (I smell BS). More to come....
Old December 12th, 2019, 08:06   #10
rmilchman
Just got a call back, that VW will cover it. Should be installed on Monday, tested Tuesday morning and hopefully the car is mine again Tuesday night.
Old December 14th, 2019, 06:20   #11
06bluebeetletdi
Great news
Old December 19th, 2019, 02:16   #12
Fastbird
Sent you a PM.
Old January 1st, 2020, 06:29   #13
Mikestdi
Dropped my 12' at the dealer this past Friday for the same issue. Although, I did have a pending P1007 Torque Difference Cylinder 4 code. I have about 1400 miles left on the 4/48 warranty, fingers crossed.
Mikestdi is offline   Reply With Quote
Old January 1st, 2020, 06:51   #14
06bluebeetletdi
Did you get the letter extending the warranty another 3,000 miles? I received one for my Passat.
Old January 1st, 2020, 06:53   #15
Mikestdi
Nope. Did they say what the extension is in reference to?
Fixed '12 - Cold weather hesitation, stink. ekiM VW Passat Family (NMS and B7) TDIs (2012+) 12 December 12th, 2017 05:57
B5.5 hesitation/stumble when cold, getting worse, please help negev VW B5 Passat TDIs 3 November 16th, 2016 00:08
2010 tuned TDI Torque difference codes help Demolitionman VW MKV-A5 Golf/Jettas 0 July 19th, 2013 10:20
'10 Golf stumble in cold weather Rule10b5 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 8 November 2nd, 2010 14:15
Cold weather hesitation with BD cawfebug Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 10 December 20th, 2004 18:17
Page generated in 0.14179 seconds with 13 queries
[Output: 122.74 Kb. compressed to 102.64 Kb. by saving 20.11 Kb. (16.38%)]
