2005 Jetta wagon...need to know the name of the air pass-through grill on the left and right side of the front bumper. Can anyone tell me the technical name of these? I need to replace one.
On my Jetta the right-side one [10] is designed to pop out so you can install the retrieval eye. I think the left side [11 on jddaigle's link] pulls out easily also. They have part numbers on the plastic casting.... which will make it easy for your friendly local stealership parts guy to order what you need, if you go that route.
