So my 99.5 Golf speedometer/odometer/cruise stopped working along with a wonky fuel gauge. Just like that a few days ago.
Did a bunch of searching on here and tried all the usual sugestions including 2 new speed sensors (just in case the first new one was bad), the sensor drive gear is not broken or stripped, it turns as it should when you drive the car, fuse #7 is fine, all the wiring looks good and the ground to the switch checks out.
Any more places I should look/check?
Thanks for your time.
