AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
2002 ALH with automatic, 128k miles ........ new TB (the works)
So, the guy had his IP rebuilt primarily due to the electrical connector being cracked there on the side. Did the TB job while there.
Anyway, he could not get it to start.
He brought it to me. This is the first one to stump me!
Question! Would a 10mm IP work with the injectors that come with the 11mm pump? I'm not sure if the pump is 10 or 11mm (how can I tell?).
Next, it appears the guy broke loose the center nut on the IP. The paint marks from the rebuild do not match. If so, is that something I can re-set? I know the Bentley says it cannot be done at a regular shop... meaning it needs to go to a specialty shop. Something I just thought, I could remove the sprocket and rotate the end of the pump shaft to see if the timing appears to be "on cam" just as the hole aligns for the IP pen lock........... could try that!
Lastly, the air is out ......... sprays plenty of fuel at all four injectors!
I do have a known good 10mm IP that I can put on to rule-out anything else, but if it will not work with the 11mm IP injectors, that would be a waste time.
Suggestions welcome!........... be back later tonight!
