owen3439
A small 1/4" hose located on top of the air intake duct keepsa popping off. It is not secured or clamped, just pressed on. What is this hose for? Keeps popping off. Doesn't seem to affect driveability.
hose <> holesDodoma said:Usually when you see holes plugged, they are meant for some us of the same component on another vehicle (such as passat). You may seal it permanenty by welding of using J-B Weld to avoid it popping out.
Yes it does appear like an s curve.Elfnmagik said:I can't view the pic here at work, but is it the S-bend looking one with the two rubber standoff pieces?
Hairspray would probably do the trick just fine too.alnmike said:Hmm, how bout getting some locktite and slipping it on, without driving it overnight. Dont want anything strong enough to never be able to remove it, and thats a really weird place to put a clamp.
