Old January 7th, 2011, 14:54   #1
Curkkic
Curkkic's Avatar
Default I need my turbo rebuild
i have a 22/56 turbo seals are shot and it attempted a run away on me. caught it soon. there is play in the shaft, however it didnt self destruct. although i suspect it was very close to. i can ship it where ever. let me know if you have a shop and can take care of this reasonably priced with warrenty.
2002 Golf TDI 4d With 32lph injector nozzles a "special" turbo, custom setup. avg about 44.9 mpg. Caution contains GREMLINS
my old jetta V 0-100 run uphill.
http://myspacetv.com/index.cfm?fusea...deoid=33067965
Curkkic is offline   Reply With Quote
Old January 11th, 2011, 13:08   #2
Curkkic
Curkkic's Avatar
bump* anyone on here rebuild these or should i check somewhere else.?
Old January 11th, 2011, 13:58   #3
rackaracka
I'm giving a rebuilder a try with a non-destroyed VNT15. I'd suggest you give them a call and see if they can help you. They are www.gpopshop.com and you will probably speak to Jim or Gerry. They are very nice on the phone.
I can't speak to if they do quality work, or if it is safe to do a rebuild on your turbo - but I am giving them a try on a known good VNT15 turbo that was starting to blow by some oil.
2002 Jetta Wagon TDI Auto- Reflex Silver/Leather/Monsoon
95 Dodge 2500 w/Cummins TD - Straight piped 4 "
98 Beetle TDI 5spd - Herbie/11MM/VNT17/pp520/RC3/Mcnally Gauges/SBC2 Endurance/Bilstein HD's/Dieselgeek Panzer FMJ/3" Kerma turbo back
rackaracka is offline   Reply With Quote
Old January 11th, 2011, 15:07   #4
Curkkic
Curkkic's Avatar
ill check them out thanks for the info
Turbo rebuild Eastcoast43 TDI 101 22 May 10th, 2011 07:49
Turbo rebuild Fireguy2008 TDI 101 10 August 24th, 2010 15:51
New Turbo or Rebuild Busterman TDI 101 1 March 13th, 2009 22:52
Rebuild turbo or go with new?? barley TDI 101 2 May 23rd, 2007 20:07
might need new or rebuild turbo poppy1 Ontario 1 May 4th, 2006 05:35
Page generated in 0.15126 seconds with 11 queries
[Output: 64.11 Kb. compressed to 57.22 Kb. by saving 6.90 Kb. (10.76%)]
