Blower Not Blowing Air
CSL06TDI
Rockford, Il
'06 Platinum Gray Pkg 2
I have the Climatronic and the lights light up as if the fan is blowing faster but no air comes out of the vents. I am about to go check the fuses but not sure which ones. Any suggestions ???
Thanks in Advance.
MyAvocation
Hoffman Estates, IL
2017 Passat SEL TSI
When in doubt, check them all. Seriously, its been reported that fuse layouts differ between A5 models, so I wouldn't want to give you incorrect info. Also, there are other reports of loose fitting sockets -- where fuses simply creep-out over time.
Have you searched the forums for similar posts?
CSL06TDI
Rockford, Il
No luck with the fuses..... I did a search but not much help. Also tried bangin on the blower motor and had no Luck!!!
Just got the car back today from getting a new camshaft and lifters. This happened right before I took it in. Another Bummer!
