Fasteddie10
- Joined
- Jun 23, 2011
- Location
- Illinois
- TDI
- 2004 Jetta Wagon TDI, 2-2005 Passat Wagon TDIs, 2-2004 Passat Wagon TDIs
2004 Jetta BEW PD EGR Pipe Cracked in Flex Joint, 3rd time.
Purchased the car with 116k miles, the car started whistling at about 122K. Found the EGR Pipe cracked at the flex joint. Had dealer install a new pipe, 1200 miles later the pipe cracked and whistled again. Another new pipe was installed and less than 500 miles I see the flex pipe is cracked again, one joint is loaded with black. The two new pipes appear to have the flex area moved from the first one that was on the car when we purchased it.
Any ideas?
Thanks,
Fasteddie10
Any ideas?
Thanks,
Fasteddie10
