p11hlf
hey guys
i have been lurking on the forum some time but have come across a problem with a new car i have purchased.
the car started to whistle from around 2500rpm until around 4000rpm
i managed to log on my ebay vag com cable (sorry guys) the block 11 and block 03
i did a run in third gear from 1700 to 4500
the pic above is showing boost pressure, notice the delay?
so i logged the maf too and
it shows two things, the maf is ****ed and the specified is set to 1000? is this set by the superchips remap?
obviously i plan to spray the maf and log again but would like some help along the process. could this all be causing the whistle?
i also get a fault code for implausabe signal from the maf.
i await your help
many thanks
phil
i await your help
many thanks
phil
