babydoll
164 k been changed from auto to 5 speed , motor mount broke off block rear, timing belt tore up from broke mount, seems to have aftermarket flywheel put a belt on it today and got it started very rough, starts fast not sure on timeing marks on flywheel different from any I have seen lot of spliced and cut wires under the hood, return line blocked off coming out of the pump, return from the injectors is going back to the return at filter, straight exhaust 1 1/2 inch I think , complete egr delete it looks like , its going to take a while , anyone know anything or seen a blocked off return line at the injection pump? more too follow I'm sure,, I guess it was worth $ 300 bucks
