DasTeknoViking
Sorry for the shameless plug but I got a GT15 for sale
I've done a bunch if them if you need a hand. We even made our own tool to make it easier. Without a tool it's a PITA and almost requires 2 people.Had the motor mounts replaced and now there's MUCH less vibration.
Next on the agenda: Rear axle beam bushings.
If you are referring to the timing graph plot point moving vertically while watching the timing, I consider it normal for the timing to move up and down 4-5 ploy points.Timing was slightly above midline withg no adjustment!
I do see a little movement in the timing; I'm wondering if the crank pulley needs to be changed.
Tony
Well, yeah.Always a good Idea to check your crank pulley, but wouldn't that have been a good idea when the belt was off?
Interesting! I am often annoyed by the 'oddball' horn button on the Passat.The clock spring and everything fits like a glove for an OEM look.
Got a picture?I had the A3.5 Cabrio wheel on in just under 5 min in my driveway last night !
How are the codes and fixes coming along? I know I didn't get around to replying as I said I would.
