I had a stainless line made with -an fittings and bought 2 metric to standard fittings off summit racing. Should be the same fittings/thread as stock alh feed line. There is a thread on here that tells all the sizes and all to make the feed line.
It is not the banjo bolt im looking for, I got that, I'm looking for the fitting that goes in between trying to find out which thread pitch and thread so I can hook it up to my oil feed line
