What are these cut wires?
Maillemann
Southern WI
'96 B4 Passat
While looking over the wiring harness on my '03 Jetta, I found this section that had apparently been cut. Nothing that it could/should have connected to is obvious. This is in the vertical plastic channel between the brake fluid reservoir and strut tower, just before the wiper well. Any idea why it's like this?
Nero Morg
OR
2014 A6 TDI, 2001 Jetta TDI, 2014 Passat TDI
Well, if I had to take a shot in the dark.... Brake pressure sensor? Like the car might have had ESP but someone coded it out? But I think that sensor is only 3 wires and plugs into the bottom of the master cylinder.
Only other thing it could be is if someone did a manual trans swap and that's where they snipped the harness at.
oilhammer
outside St Louis, MO
That is the glow plug harness, and notice you have a new one overlayed. This is normal. Probably not too many 2002-2003 ALHs left that have not have had this done by now.
Metal Man
Sunbury,PA 17801
1998 NB TDI, 2006 Jetta TDI, 2014 Tiguan gas, , 2019 E Golf X2
I usually cover them with liquid electrical tape so they aren't as likely to worry somebody.
