RedTDIowner
Since I could not find this leak I have taken it to two different mechanics and they can not figure out this leak either. We replaced the coolant O ring on the right side of the head by the brake master cylinder but that did not fix the leak. The only time this leak happens is when I drive my car cold for just a few miles and then turn it off for a couple hours. Somehow in that time while it sits it releases about 10 to 20 ounces of G13 onto the ground. I have a skid plate so its really hard to tell exactly where the leak is coming from. If I reach my hand all the way around the head to feel the coolant lines there is no leak that I can tell. The timing belt was recently replaced along with the water pump so its not that. This has happened now about a half dozen times over the last 4 months. Now if I drive it more than 5 miles it does not do it. It only happens if I drive it a few miles and then let it sit. Then when I walk out I see the big puddle on the floor. Any ideas?
