norel
Something weird happened. Car is stock alh 5speed, pd 150 intake, egr asv delete, bosio. 205 nozzles, 240k miles. After an afternoon of adult beverages, I decided to drive 1/4 mile down the road to the other driveway entrance at the shop and leave my car there for the evening. Car hadn't run for 6 hours I let it warm up 5 minutes. Ambient temp was 40 ish.
So here's what happened. Drove 100 yards, turned out of driveway, floored it, broke loose, shifted out of 1st at 4k?, floored it again, engine hit 4000 rpm, and stopped running. My ride home was right behind me. He said he saw a tremendous cloud of dark smoke, but couldn't tell me what color it was. The first thing I thought was failed tb tensioner. I then made the poor decision to attempt to start car. It started right up, bought wouldn't Rev up over 1000 rpm? I limped car back off road maybe 100 yards and parked it.
Next morning, car started right up at 20 degrees, Sounds quiet, runs fine. I replaced the fuel filter in case it had collapsed, replaced filthy air filter too. There Maybe slightly less power/smoke but it's hard to tell, as I'd been messing with iq lately. I know I should have confirmed static timing before restarting the car. I've sort of been looking for an excuse to put a pd shortblock under the alh head I've been working on, and I may have found it...
I'm guessing I probably got a slug of oil out the turbo/intercooler and shortened a few rods? I've been ignoring what seems like a 4th/5th gear low rpm boost spike/haven't reinstalled boost gauge. In the next week I should be able to check timing/compression and log boost.
My questions;
what would make It stall out like that?
With all that dark smoke (oil?) why didn't it just run away?
What would make it not Rev up til next day?
I'm really more familiar with id engines, but if engine is mechanically sound, this had to be fuel or air restriction? Or just enough oil hydrolock to stall out without putting a hole in the block?
Thanks for reading.
Input appreciated.
My questions;
Thanks for reading.
Input appreciated.
