p0wer
- Joined
- May 21, 2009
- Location
- Jyvaskyla, Finland
- TDI
- Golf 3 -94 1Z 377hp, Golf 3 Cabrio 4-Motion 1.8T 620hp, Golf 3 Syncro 2.9 VR6 HX52, Bora AJM 4-Motion 2260vk +120% Firad, Passat 3B Syncro AFN 2260vk
Crap or not, but here you can see one well working 350+ 1Z, and still heading over 400hp after having more bigger nozzles ( 5x0.4mm+ ). Engine runs already lean with 0,341mm nozzles and 11mm pump which voltage is already 5V on wot, especially when boost is raised a bit. This pump/nozzle combination is good up to 370-390hp usually depending pump voltage map. With NOS you can have almost that much power that fueling allows, but with this setup there is no benefit from NOS because more fuel is not available any more. But, maybe i´ve done something wrong then when it works...
Though, never expected for long lifetime for this engine, that´s why it´s use is also really cruel to find weakest part. Still no problems after 5000km +. I´ll drive another dyno run on local shop after few time, there is plenty more of inertia to have more better torque curve and numbers from it, and have turbo wake more earlier (on street there´s full boost on 3500-3700 rpm ). Also i´ll raise limiter bit over 6000 for next run.
jsrmonster, can you describe what does "overfuel" really mean in the present case? What injectors, turbo, injection advance and voltage you had on IP? IAT? Did it fail from long WOT? From my opinion, 1Z / AHU piston is more durable especially when they´re modified, than PD or ASV piston, since there´s much more material because of lack of oil channel. There are plenty of cracked PD pistons too, so this is not fully abnormal to see one (though, usually it is consequence from bad injector or tune, on VE or PD, otherwise all engines would fail same way one after another).
On your link, there seem to be early and later 1Z pistons. Piston which is cracked, seem to be later and with wrist pin bushing. As far as i think, my Golf engine must have bushings because it´s durability this far. Also, there is no difference to AHU piston.
Fixed the link for 0-180kmh video, sorry for quality: https://www.youtube.com/watch?v=c3e5yFjly7U
