2bitthugs
I picked up a 1756. Along with some Pd150's. Will see what she can do with that combo!!
Overboosting to 30 then settling to 26? If so, nothing to worry about.I have a 1752 and I'm boosting perfectly if I step on it but if it's light acceleration to bring boost up gradually and then step on it it will over boost to 30 PSI. The tune should be 26PSI. Would I need to adjust the actuator screw?
My 1749 does this, Malone tune. It will overboost to ~30 and settle back to 26-28, usually by the time it is settling down to 26 I am crossing 3,000 RPM where the tune is programmed to step down the boost anyways..I have a 1752 and I'm boosting perfectly if I step on it but if it's light acceleration to bring boost up gradually and then step on it it will over boost to 30 PSI. The tune should be 26PSI. Would I need to adjust the actuator screw?
Did you adjust the actuator? It has to be shortened several turns to get the vanes to close at low rpm.
A tune cannot account for the hardware difference between a Garrett and Borg Warner actuator. From the factory, the Garrett starts moving over 6 mmhg vacuum. You need to shorten it so it starts moving under 4 mmhg. Software can't make up for a hardware mismatch (N75 meant for a Borg Warner but controlling a Garrett can).
***!! I have that turbo and a Malone stg (4)...adjusted for that turbo and etc.
Had a stock turbo/VR6 clutch/Stg2 before and.......
And I will say it is a lot WEAKER than than my Stg 2 Malone and stock turbo....?
Tune issue or WHAT? Totally not happy!.....kind of want the old failing turbo back..... Hello, Malone?
Did you ever end up installing the 1756 pd 150 combo? What did he do or planning to do for a manifold?I picked up a 1756. Along with some Pd150's. Will see what she can do with that combo!!
Yup, been installed for a few months now. Not sure if your asking about the intake or exhaust manifold but i have a PD150 intake installed. And an exhaust manifold from dark side.Did you ever end up installing the 1756 pd 150 combo? What did he do or planning to do for a manifold?
