Here is what I just installed. The tank and sending unit are out of a 97 Jetta TDI, in order to get my Passat cluster reading properly. The pump I used was a Facet FEP87SV. It is rated for 1-8 psi @ 45 gph. All lines are new 5/16 ID line.
Here are the readings I got with a vaccum/pressure gauge on the feed line, teed in before the 100 micron prefilter.
With pump off:
At idle - 1" vaccum
Full Throttle at about 3500 RPM - 10-12" vaccum
With pump on:
Key on, engine off - 4 psi
Engine idling - 3 psi
Full throttle about 3500 rpm - .5-1.5 psi
Edit: One piece of information that may be key. I have Bosio PP520 injector nozzles and a stage 3 malone tune for 18 psi of boost.
As far as power goes, I didn't necessarily notice any more power, but what I did notice is consistent with the timing logging somebody did a couple pages back. The power delivery feels smoother, and a bit more responsive.
I wired a relay to power the pump with a 12v ignition source and the relay is ground triggered by the oil pressure switch (on the filter housing) so the pump only runs when the engine is running. The relay is easily accessible so I can jump it out to bypass the oil pressure shutoff if I want.
One interesting thing I found was once the motor warms up to OT, the oil pressure switch (brand new) stops sending ground at idle due to lower oil pressure. This basically makes it so the fuel pump I installed only runs when the motor is above idle once its warm. At first I thought this was an issue, but it should work to my advantage because the pump will only be working when there is a demand for fuel. This should prolong pump life.
I have an oil temp and pressure gauge in the car, and once the oil temp gets to around 200 degrees, it runs about 5-10 psi at idle. I do not have an oil pressure light on on the dash(yes it works), so I figure its operating as it should.
Under hood pic of my new prefilter and new lines running from the filter to the IP.
Under car pic of lift pump. I made a bracket (hard to see in pic) that utilized the factory studs under the car that the CIS pump was mounted on. I also used the factory CIS pump wiring to get my +12v from the relay at the fuse box to the pump in the back.
