Last night I was forced by traffic into a huge (unmarked!) hole in the street created by the gas company to fix a line (this is going on all over New Orleans right now). I wasn't able to brake in time and had nowhere to swerve so both passenger side wheels went right through it and sortof "bounced" out of the hole. After bouncing out of the hole the car started shaking violently and the engine started making really low (like 2 octaves lower than normal growling noises).
I immediately pulled off to the side of the road thinking that I had blown out one of the tires. Nope, the tires were fine. I opened the hood and everything sounded ok from outside of the car. I looked underneath the car and everything looked fine as far as I could tell. Inside of the car though the engine sounds really really loud and really really low-pitched. Inside the whole cabin is vibrating furiously (so much so that it rattles your teeth). This noise and vibration is heard/felt both in neutral and in gear. I was less than 2 miles from my house so I drove the car the rest of the way home but I was afraid to go any faster than about 20MPH because anytime the RPM's got above about 1500 the noise and shaking got about 100-times worse. I also noticed a significant loss of power (i.e. I was having to really push the pedal down just to get it to go 10MPH).
I'm thinking that I either broke a motor mount, or something in the linkage between the engine and the transmission, or the transmission and the wheels is busted. Does this sound right? Does anyone have any clues/suggestions? I am scheduled to limp it to the dealership tomorrow. How much do you think this will probably cost me? I'm hoping that I can get the city or the gas company to pay the damages since the hole was not marked.
Thanks!
Thanks!
