FS 2003 TDI Jetta 5 Speed Manual in Maryland
noplug
Southern Maryland
2003 Jetta GLS
SOLD SOLD SOLD!!!!!!
I am selling my beloved 2003 Blue 5 Speed manual Jetta here in S. Maryland.
(I just bought a 2015 Jetta TDI SEL 6 Speed Manual)
She has 418,000 miles, well maintained but well used
The Good:
Always professionally maintained by Oliver (TdiRacing) with top line Amsoil or Castroil oil, Redline Trans oil, 2 Micron Bypass Dieselgeek filter,
Power Service diesel additive or EDT(Every Day Treatment) always used, (never a grease car), top of the line parts installed for all services.
This is a southern car from South Carolina. Body is solid with no rot.
Power Sunroof and power tinted windows.
Engine runs strong and the AC blows nice and cold, the heat is excellent, new thermostat 3K ago.
I have never had it in an accident except backing into a pole slowly, rear bumper paint cracked and flaked off.
New front brake/calipers/rotors/fluid 2K ago
OZ 16" Superlegerra wheels(super lightweight) with Conti DWS Extreme tires 50% left, filled with Nitrogen since new.
Rocketchip 2 with Sprint 520 injectors installed.
New Clutch/Flywheel/Pressure plate/release bearing 20K ago (South bend Stage 2 I believe, should last a long time)
Trans shifts cleanly, never any problems, use Redline Gear Oil
EGR Delete with Race Pipe installed and proper programming.
New timing belt 20K ago, Prof. done with bronze water pump (100K unit)
New OEM cam and lifters replaced @ 320K by Oliver Wegener with timing belt and bronze water pump.
3 Spoke VW Steering wheel
Audi TT bushings installed with touring shocks & new dogbone motor mount (Handles very well).
DieselGeek 5 Speed Short Shifter
Great quality tinted windows (street legal, passes inspection)
Vent Visors all around in perfect condition
Panzer Plate Engine protection pan.
Heated leather seats (Upgraded)
Heated mirrors both sides work, driver's side is tinted blue factory glass.
Monsoon audio system.
Oettenger front Grille
Bosch AGM Battery 3 Years old (Top of the line)
Loads of extra maintenance parts including new aftermarket headlights in box and new glass lenses
for existing stock headlights in box still, oil and air filters, stock injectors.
The Bad/Ugly:
Engine light has been on as long as I've had her, cleared it the other day and it's the glow plug harness
error and has stayed clear for now.
Airbag light is on since installed leather heated front seats
Possibly could use new glow plug harness (Still starts @ 5 Degrees F)
Clear coating on paint is peeling off on hood and roof only, still nice on sides.
Console hinge broken (Have a whole Black leather one for replacement)
Headliner is coming loose and sagging
Passenger seat heat doesn't work (Driver's works)
Two holes in roof from prof. installed Ham radio mounts (No leaks)
Left rear quarter has antenna mount, prof done.
Rear bumper paint is cracking/flaking off (I bumped a pole)
Fuel filter weeps a bit, we can't seem to see why...
Various body dings and scratches, 2-3 surface rust spots on front end no body rot at all (Southern car)
Overall:
This is a great TDI and it's been super reliable. The chassis is still tight with hardly any squeaks or rattles.
I have owned this TDI since 2010 and this is #2 of 4 owned, I know how and have properly maintained this TDI.
I have bought a 2015 TDI Jetta 6 Speed Manual SEL and have too many cars in the corral, she need to go.
I just want someone that appreciates a great reliable TDI to drive for a good price.
More recent images will be uploaded soon.
-Todd (301)848-7649 feel free to call or Text me.
NEW PICS!!!!
https://image.ibb.co/iPRG1w/003.jpg
https://image.ibb.co/nrEfTb/IMG_3608_484801646.jpg
https://image.ibb.co/gJyJEG/IMG_6346_907254641.jpg
https://image.ibb.co/m4EEob/IMG_6637_1807864816.jpg
https://image.ibb.co/gpe3gw/Super_Leggera.jpg
https://image.ibb.co/cywS8b/Super_Leggera2.jpg
noplug
Southern Maryland
2003 Jetta GLS
Seller Bump/fresh pics/lowered price $2300. she must go!!
I've added new pics tonight and lowered the price on this ultra reliable
high mileage TDI with lifetime 43MPG actual fuel mileage.
Don't let this one go!
-Todd
nomorotors
Athens, AL
99.5 Jetta 5-Speed, 01 Jetta 5-Speed, 02 Jetta 5-Speed Conversion, 04 Passat 5-Speed Conversion, 05 Passat 5-Speed Conversion, 05 Passat Wagon
Someone will snag it within the next few days.
Nice ride!
-Jason
noplug
Southern Maryland
2003 Jetta GLS
Bump for price lowered to $1900.
Good solid TDI, best year 2003, need some cosmetic love and many miles left!!
noplug
Southern Maryland
2003 Jetta GLS
Update: Just pulled CEL code is only the glow plug harness
Just checked and cleared the CEL and glow plug harness (or all 4 glow plugs-not likely) came up and cleared.
This is a solid car with no rot and tons of life left. Jeff from Rocketchip installed the injectors (Sprint 520's)
and Rocketchip 2 at approx. 270K and said this one was very stong and should run for many hundreds of thousands of miles.
I still get 43MPG combined all the time. (stopped using Fuelly but you can see the trend).
Ask me a question, I'll reply I'm bored at work today!
-Todd
noplug
Southern Maryland
2003 Jetta GLS
Adding a couple photos taken this morning.
I washed her last night (yes in the cold!) so I thought I'd add a couple more pics!:D:D
tdidieselbobny
Stafford,NY (WNY)
'03 Galactic Blue Jetta TDI, '15 Silk Blue Golf Sportwagen TDI
How many keys/fobs come with it? Are they power or manual windows? Sunroof or not? If you clear engine light, does it come back right away or does it take a few days?
noplug
Southern Maryland
2003 Jetta GLS
Power Prof. tinted windows & Sunroof, 2 Keys
Power windows are tinted, Has Power Sunroof, One original key fob and one Valet key. Cel light hasn't come back
on yet and it's been a few days now. Was throwing a glow plug harness code.
Thanks for the questions!;)
-NOPLUG
tdidieselbobny
Stafford,NY (WNY)
Yeah, in NY you can only have 1 not ready in the engine monitors from either '01/'02 on up or else it'll fail inspection, and probably the tint would fail also..... thanks for checking, will have to do taxes and see if I come close.
tdidieselbobny
Stafford,NY (WNY)
Does the car have a hitch? I noticed in one of the pics that it looked like an antenna or something on the rear. Do you have any pics of engine bay and injection pump?
noplug
Southern Maryland
2003 Jetta GLS
Yes the car has a hitch and antenna mounts included
I am an amateur radio operator (Ham) and have logged many contacts
all over the world with this great little car.
I'll take some engine bay shots later today (I'm on night shift) and
put them up.
This is a solid car with no rot at all, it was driven most of it's life in
South Carolina, Spartanburg.
-Noplug:D
tdidieselbobny
Stafford,NY (WNY)
Thank you! I actually didn't see that they were on the 2nd page on my phone....
tdidieselbobny
Stafford,NY (WNY)
Being that its tuned, did you also do the immobilizer delete, and did you ever do the ventectomy to the fuel tank?
