ArturCosta
In this position the max I measured was 800ºC with smoke and only 1.3bars.Rub87 said:800° after turbin says me that you're easily making 900°c before.. if you take a car with DPF you can see in channel 75 temp before turbine, temp after turbine and temp after dpf, under full load there's often around 200°c temp drop over the turbine..
or did you measure 600° in that position?
Now the max I get is 750ºC on a long uphill. In a normal flat road it does a max of 650ºC.
I can get it a bit lower by adding 100g of boost but that goes a bit of the best A/F ratio.
Regards
