turbobrick240
- Joined
- Nov 18, 2014
- Location
- maine
- TDI
- 2011 vw golf tdi(gone to greener pastures), 2001 ford f250 powerstroke
I've been having electrical problems for awhile, specifically the passenger low beam and blinker aren't working. I thought the underhood fuse block might be the culprit because one of the fuses was partly melted but not blown. I replaced it but no change. Then I noticed the foam grommet around a thick wire bundle in the driver footwell firewall was chewed up. After removing the battery I can see that at least two thin wires in the bundle are chewed clean through right at the firewall. I'm wondering how to go about removing the bundle to either splice or replace it. Any advice is appreciated, thanks.
