diesel fumes in cabin
gsea
commack,ny
2003 jetta
newbie tdi owner. 2003 5 speed. upon startup and while defroster or heat on diesel fumes entering cabin. any thoughts?
JASONP
Guelph
2015 Golf TDI Comfortline 6spd
Cabin pressure vent in LR wheel well stuck open or damaged?
joetdi
Midwest
2-2002 Jettas W/Auto
I would check to see if you have any exhaust leaks anywhere first. Including under the hood.
TDICADDGUY
Blaine, MN
2012 BMW X5 35D
Could also be the flex section in the downpipe...which is where mine is coming from. No worries...perfect excuse to install a 2.5" SS DP from tdiparts.com :D
simbolo
USA
2002 VW Jetta
my issue was the downpipe, one of the 3 bolts that holds it to the manifold had a nut that was seized halfway on it, thus resulting in the downpipe flange not being properly clamped against the manifold. Found this when I was replacing the downpipe... unscrewed the whole bolt from the manifold and placed a thick washer in front of it.
now i can have the cabin fan running on startup and idle and not smell any fumes
