Really didn't get on it to hard, it's a little laggy. Certainlly drivable.
EDIT Nov 23, 2010: Not laggy, just a little softer than stock. l;aggy is not really the right word.
Once I got up to full temp and punched it the FMIC hose blew off.UGH! I knew that was going to happen.
I'm running a 1.8T pancake pipe, with the IDparts lower hose. I didn't buy the idparts lower pipe because I already had the 1.8T pancake pipe. Mistake. The hose is 2.5 inches and the input on the pancake pipe is ~2.0 inches. I tried building it up with a 2 inch hose and sliding the 2.5 hose over it, but it blew off, I kinda figured it would. Soon as it did, I knew what happened..
EDIT 11/22/2010: Fixed my IC Hose problem, welded a 2.5 inlet on the stock pancake pipe.
Drove the car about 30 miles, Car has a lot more low end, Mark sent me a new tune to fix another problem, and it seemed to help the low end also. Over all I'm prettty happy, but later I will get larger injectors, a better intake and a better clutch.
Right now I can slip the stock clutch if I get on it hard in fifth.
Summary of Mods: Gutted stock PD100 intake, Ebay FMIC kit, Idparts lower turbo hose with 1.8T pancake pipe.17/22 Turbo from Idparts, 3 bar map from idparts. 2.5 down pipe and 2.5 open exhaust. malone Stage 4 tune.
