Old April 7th, 2012, 13:46   #31
cooper426
Rub87 do you have just one muffler or did you add a second? I am wondering where i can put my second muffler. At the moment i have only hav one muffler after the downpipe. I was thinking of putting another where the onriginal was, behind the axle.
cooper426 is offline   Reply With Quote
Old April 7th, 2012, 13:48   #32
Rub87
the car had originally only a muffler in the rear, now I added in the middle of the car one like it is done on a golf mk3, it actually is a golf mk3 afn muffler =) (long narrow thing)
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old April 7th, 2012, 20:23   #33
storx
Plastic manifold.... Don't think so buddy today put down 1102hp on his turbo 2.5 rabbit with plastic manifold
I put down 195whp/385wtq today uncorrected in Denver Colorado so elevation is a biotch
Da Diesel Build
storx is offline   Reply With Quote
Old April 7th, 2012, 21:28   #34
storx
As soon as I can get my scanner working I'll post dyno sheet but for now here is the better of the dyno pulls. This dyno pull is with stock exhaust flapper valve back.
http://www.youtube.com/watch?v=nHfMh...e_gdata_player
Da Diesel Build
Old April 7th, 2012, 21:42   #35
storx
Buddy's 2007 rabbit 2.5 Turbo gt6889 awd
Put down 1102hp/711tq on e85
http://www.youtube.com/watch?v=0csSFqA3vcg&sns=em
Da Diesel Build
Old April 7th, 2012, 21:48   #36
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
bye bye headgasket.
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old April 8th, 2012, 00:26   #37
storx
Originally Posted by greengeeker View Post
bye bye headgasket.
Nope the coolant pump is geared for extreme flow and was relieving excess pressure
Da Diesel Build
Old April 8th, 2012, 00:31   #38
storx
Same guy that built the wabbit has this one for daily driver.
1158hp/1098tq
http://www.youtube.com/watch?v=eME-QNB-4cI&sns=em
Da Diesel Build
Old April 8th, 2012, 03:18   #39
Rub87
front wheel looks like my ibiza before I put poly bishungs in there =) they didnt want to dyno it because the wheel went too far forwards and went off the rollers
Old April 8th, 2012, 14:55   #40
Whitbread
Whitbread's Avatar
TDI(s): Several
Now do you see why I recommended a CR TDI over any of the older ones in your thread a while ago?
I'd love to get my hands on a 2010 6 speed cup car and have some fun....
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old April 8th, 2012, 15:18   #41
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
what fun can you put together for my 2010 TDiCup 6spd? I havent put in the Amarok/T5 injectors yet (I have them). Is the 3L Toureg fuel pump a direct bolt in?
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old April 8th, 2012, 16:09   #42
blizzard60
blizzard60's Avatar
Ah, now here's some good stuff!! So there are some OE upgrade options out there for the cr cars?
What can you get out of the cr engines with only tune and turbo? Again, in a car where DPF won't be a limiting factor. Are the injectors and hpfp the limiting factors?
Storx, you got a thread that discusses the upgrades you've made?
blizzard60 is offline   Reply With Quote
Old April 8th, 2012, 19:20   #43
bhutchins
bhutchins's Avatar
matt pm'd me back and thought I should get 240-250 smokeless with the T5 injectors, my exhaust and tune. (exhaust only for the reduced EGT) my FMIC will help the EGT's also
Old April 8th, 2012, 21:51   #44
Charrigan
TDI(s): 09 Jetta
195whp/385wtq
I don't see how 385wtq is even possible with your current setup. Even with aggressive tunes. Sounds like the dyno you were on was reading EXCESSIVELY high or you made a typo and meant 285wtq.
Charrigan is offline   Reply With Quote
Old April 8th, 2012, 22:17   #45
blizzard60
blizzard60's Avatar
WHP? Wow. Without a turbo upgrade?!
I'm confused why a 16v pd exhaust manifold won't bolt up to a cr. Would ryanp's manifold not work? Are the cr turbos electronic actuator or vacuum?
The last round-up geezerb Road Trips 3 July 17th, 2010 10:28
03' Jetta ignition key spins cycl. round and round troymobley VW MKIV-A4 TDIs (VE and PD) 1 July 8th, 2009 16:15
Pictures of the CR140, enjoy... bhtooefr General VW Discussion 8 January 28th, 2008 06:57
The Steering Wheel of the Car Goes Round and Round, Round and Round Haiku TDI Eastern USA 342 February 13th, 2007 07:06
The Steering Wheel of the Car Goes Round and Round, Round and Round (x-post) Haiku TDI TDI 101 0 January 21st, 2007 15:42
Page generated in 0.19930 seconds with 13 queries
[Output: 130.39 Kb. compressed to 109.10 Kb. by saving 21.29 Kb. (16.32%)]
