Damn it, I knew I should have done that damn DIY.
You got the DPF out? Thats the hard part. This is the fun part. lol.
The charge pipe takes the air from the turbo to the FMIC. You'll need to remove the air box, battery and battery tray to gain access to it. Its a hard black plastic pipe and its fasten to the block by two T30 torks screws. Its kinda of a PITA to get out with out removing other hoses and such but not impossible. I just did 2 this past week.
That brown-ish pipe that is going to the front of the motor and to the EGR valve on the intake manifold side is the HP EGR pipe. Those 2 rusted nuts are what hold the block off plate onto the exhaust manifold. They are 12mm.
You see the black body labeled "LP EGR Valve and EGR Potentiometer and EGR Valve N345"? DIRECTLY the right of that little dot (if you're not color blind its yellow) Is a pipe. That is 1 of the coolant pipes. Then just above that is another pipe. That is the other coolant pipe.
They have some fancy hose clamps on them and this tool come in handy in more than just this 1 area.
http://www.amazon.com/OTC-4525-Cabl...sim_263_2?ie=UTF8&refRID=1TGVC1GH2SN8YJYVX5KJ
Once you remove the coolant hoses, you're going to spill a considerable amount of coolant unless you have these.
http://www.summitracing.com/parts/wmr-w83205
I sell for summit btw, if you're interested, pm me.
If not, get yourself a gallon of coolant from the dealer and premix before hand because you're gonna loose a lot of coolant.
Next, to remove the EGR cooler there are 4 or 5 T30 tork bolts that fasten it to the block. Remove them. The EGR cooler should be loose by this point.
You've got 2 sensor that need to come out. Both are threaded into the EGR cooler via a 14mm fittings. Undo bofe'ms and get them out of the way. The hard line you see going across the EGR cooler gets removed. Remove the 12mm nut on the heat shield holding the hard line in place. Trace the hard line to the top side of the engine and remove it. Put the 12mm nut back in place and make it snug.
That short metal tube with the line coming from the phrase "To the Intake side of the Turbocharger" gets unbolted from the EGR cooler (I believe, 10mm triple squares) then you just gotta mess with it, whisper sweet nothings and mickey mouse it out of the turbo. There with be a rather larger grommet in the turbo where that pipe came out of, remove it.
Then you'll need 1 of these to go in its place. I bought mine at autozone for around $6.
http://www.amazon.com/Dorman-Help-02601-Expand-Tite/dp/B000CO8ZN8
Dont put it in just yet, the EGR cooler still needs to come out.
Now, you'll need to remove that big 27mm bolt. It's a banjo bolt. That holds the turbo support/oil return line to the block. The 2 seals for it, from the dealer, are $10. By the time you get around to remove it, most (if not all) of the oil will be out of the turbo so you'll lose very little. Nothing to worry about. Don't forget up high there is a 16mm funny bolt that holds the turbo support/oil return line to the turbo. That bolt also get removed. With those 2 out, the turbo support/oil return line can move pretty freely. NOW you should be able to remove the EGR cooler. Be careful, there is a good bit of oil and coolant in there. Idk why oil is there but it is.
Also, now you can install that Expand TITE thingy. Again, make sure that sob is TIGHT.
Now with the EGR cooler out of the way, go ahead and re-install the turbo support/oil return line.
With everything out of the way, you will clearly be able to see where the 90 degree fitting goes. MAKE SURE you have the fancy clamps on the hose BEFORE you try to put the fitting on. You will NOT be able to get the clamp around the 90 degree bend. It won't happen with out damaging something.
That fitting is a VERY tight fit. It is a REAL SOAB to get on. Just put some elbow grease into it and it will go on.
Once everything is in place, put the clamps back on, fill with coolant, burb the system and you'll be good to go.
Seeing as you'll have all of this stuff out of the way, and if you're feeling frugal, Take advantage of it and get these 2 parts to install while you're in there.
http://www.tyrolsport.com/brakes/tyrolsport-master-bracket/
Since they don't have a designated TDI bracket, call them before you order it and ask which 1 fits your car.
Also this.
http://www.neuspeed.com/247/11/0/2898/480283-tdi-turbo-discharge-pipe.html
I just saw this, this is cool.
http://www.neuspeed.com/247/0/0/3166/951060-dsg-billet-aluminum-filter-housing.html
I may get it next time I service my DSG.
If there is anything I missed, or sounded confusing, do not hesitate to ask.
