Sound deadening a Golf...any results?
TdiNC
NC
2004 Golf 4 door TDI 5-speed
So I just purchased my 04 golf tdi (200,000 miles on it) in July and realized that with it being a smaller car, the road and wind noise can be quite annoying. Has anyone used sound deadening material? Any results? Does it help? Brands?
Im not planning to thump my car out like im deaf, I just really want to reduce road/wind noise. :cool:
Also, seems as though all my windows when rolled down and back up leave a streak from the roller:(. Any idea how to get rid?
TDI_bubble
phx
98 tdi bubble
Dynamat or any variant, 3/4" carpet padding, poly fill, copious use of all 3 makes a car quite quieter!
Powder Hound
...Also, seems as though all my windows when rolled down and back up leave a streak from the roller:(. Any idea how to get rid?
There's a seal on either side of the glass. Clean it carefully, make sure you never move the glass if there's material (bird dung, dirt, messy bug splats, etc.) on either glass or seal.
Yeah, I know. We're living on the wrong planet again. Oh, well, I think we'll just have to put up with life on this planet for now. ;)
TdiNC
NC
powder hound, how do you clean the seal? do you have to take off the door panel? what would you recommend to clean it with?
South of Boston
Some folks here have added sound deadening to MKIV cars, and reported that there wasn't a big change in noise levels. Maybe others will comment.
I don't think there's a lot of wind noise in my MKIV. But I've been driving it for 10 years so perhaps I'm just used to it.
Lex4TDI4Life
NorCal
2001 Golf-Ute TDI GLS 5spd Manual
You really need to check the seals around the windows. They pull away from the frame after some time and really do let a lot of wind noise in. You may also have a particularly loud set of tires as well.
Robo48
michigan
02 Jetta 5 speed
Wheel bearings good? Often the start of wheel bearing noise is very subtle and progression is slow so you get used to the noise. I changed mine and could NOT believe the difference.....just saying
dremd
South Louisiana
06 sprinter. 03 jetta wagon premium with 6 speed ALH swap, 14 JSW
I've got about 125 lbs, of MLV, closed cell foam, and a bit of vibration damper.
I knocked the db level down by 4-5 db at 70 (very dramatic). HOWEVER my car feels no quieter, in fact I got a tin canny comment. The difference, the noise floor dropped down below the squeaks/ rattles and now you hear crap rather than engine/ road noise.
I would need to go through the car bit by bit and eliminate all of those noises to genuinely make a difference.
Also note I've got a 6 speed and a quiet exhaust if that means anything.
TdiNC
NC
Wheel bearings good although I need an alignment and new tires.
Dremd, would you say it's worth investing $500 (+/-) on?
I had steal wheels on and noticed a big difference when I put 17 Audi tt wheels on. When I get new tires early next year I will be getting bigger tires to reduce some of the noise. But I am also debating if this is worth the investment. Anymore opinions/ideas would be welcome :)
Seatman
Scotland
2014 Skoda rapid elegance 1.6 cr tdi
Sound proofing you say?
That works really well :D
dremd
South Louisiana
Worth and $ is such a subjective thing.
I probably wouldn't spend that much, but it is addictive/ keep adding thing, so you may end up in that category.
I'd make sure that everything was sorted/ upgraded prior to adding sound deadening. Tires, bearings, gears make as big of a difference, so keep that in mind.
2ManyKMfor1Tank
Grand Valley, ON
2000 Jetta
I used dynamat on my floor on the driver side, found out I had a hole in the floor. I got it patched up and it is a lot quieter now. I don't have the hood liner in place yet, but plan to dynamat the hood as well and see if it makes a big difference. I will have quite a bit of leftover dynamite if you are interested, send me a PM.
TdiNC
NC
I'm only interested if it is enough for a whole GOLF. :D
dremd
South Louisiana
Oh, yeah, some other notes.
Factory belly pan + side skirts is a noticeable improvement. I'm running a Panzer again, but plastic was nice. I'd like to get the plastic piece glued / rivited to the top of my aluminum plate.
Engine cover with good sound insulation is also noticeable. I'm using aluminum covered wool which is often times sold as hood liner/ fire mat.
Squeaks + rattles are often louder than the road noise you are trying to kill.
OlyTDI
Olympia, WA
'04 Golf
When I researched doing a quieting project on my '04, I remember coming to the conclusion that it wasn't worth it. The work that made the most difference was very labor intensive and the result was a db reduction that wasn't significant.
I think paying attention to tire noise reviews (tirerack) would provide some reduction.
ToxicDoc
Virginia, US
2001 Jetta, S7, .216
I would think doing the main door seals would give the best bang for the effort, but that's also costly. I guess it depends if you have more money or time.
Judson
Cheyenne, WY
2001 Jetta
Wheel wells were the biggest bang for the buck. Please see my post in the thread linked above.
After that, it's a tie between pulling the interior and door panels and installing soundproofing there, including the trunk, and doing the engine compartment assuming you have an FMJ: do the FMJ, add some to the hood under the liner, add some to your engine cover.
My six-speed conversion only dropped things by about 2db. Engine bay was maybe 1-2db. Wheel wells dropped noise by 4-6db. Interior/door panels only 2db. Really estimating here.
Now, running a taller final gear might make a bigger difference if the other stuff wasn't done, if you get my drift. So, take this all with a grain of salt. Doing the wheel wells really honestly did make the biggest difference.
So, I started out at around 82db at 80mph. I ended up with about 73db. That's a 9db difference, which is 8 times lower in sound pressure. At 70mph, I was at about 79-80db. I'm now at 69-70db. For comparison, my buddy's 2016 GTI measures just about exactly the same as mine.
Wish a vendor around here would source and do a group buy on door seals!
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2002 (swap from 2L gas); 2016 A3 e-tron
When you say "wheel wells were the best bang for the buck", what exactly did you do there?
Add Dynomat-type stuff to the plastic liners? Or pull the liners and apply to the body metal behind the liners? Just wondering how much work to maybe take on... :D
Fahrvegnugen
Burlington Vt
01 golf 1.9 alh gls silver
I recently opened my passenger door and the rain channel seal came off.
I’ve gotten tired of waiting for a group buy of seals so I got the window channel seal (which had split apart next to my head) resulting in significant noise reduction, I can hear the tires rotating on pavement now!
Also I got a new rain channel seal for the side that came of but they are NLA on drivers side. So someone please manufacture these seals. My drivers side one gets stuck frozen and has holes in it but it’s holding on for now.
Wilkins
British Columbia
05 Jetta Wagon 5sp, 10 Sportwagen 6MT
Make sure all of the body plugs are in place under the car. Replacement plugs are dirt cheap from IDParts, Roseland or other vendors and installation is a few minutes. They make a huge difference.
