redmondjp
As the title says, I need to know if I can use pistons from an ALH motor in an AFN block.
From searching through a few hundred posts here yesterday, all I was able to determine was that the block, head & pistons are compatible between the AHU and the AFN.
Is there any website or spreadsheet that anybody has compiled containing this type of information? I have read the TDIFAQ and it doesn't get to this level of detail. I know that some of you are seasoned gurus regarding the bits n' pieces of TDI engine parts.
Thank you in advance for any help you can provide.
